Drive line failure
Thanks,
Hence torque causes the pinon gear to force the ring gear way from it, and this will split the case.
Note, the 05 had the weakest diff case, the later year cases had more internal ribbing added to them to strengthen the cases, but even the newer case as still not strong enough to take a ton more torque before they crack as well.
To add, wheel hop will really kill a diff case faster. Hence if you did a second gear dump/full throttle with the amount of hp you have, the rear tires broke free/started to wheel hop, and will bank that you grenade the rear diff.
Or may have lucked out, and just snapped a shaft, instead of cracking the case.
If you screws up something in the torque tube (split a coupling), the noise is going to change with RPM speeds isntead.
Or is the problem just one of the axle shafts that slip socket connects to the diff on the diffs shafts instead.
As for the shaft that I showed with the spine end cracked off in the above post, that is the output shaft of the trans.
Thank so much
