427 Convertible hot start starter issues
Old Jun 24, 2018 | 09:41 PM
sdetro's Avatar
sdetro
5th Gear
Default 427 Convertible hot start starter issues
My 427 Convertible starts great with no noise when cold. If hot, the starter is slow in turning over and makes a loud pop prior to engine start. Is this a heat soak problem or something else? Appreciate your input-thanks.
Old Jun 24, 2018 | 09:43 PM
rkj427's Avatar
rkj427
Pro Mechanic
Original battery? That may be the issue, and first place to start.
Welcome to the forum!
Old Jun 24, 2018 | 10:00 PM
sdetro's Avatar
sdetro
5th Gear
Thanks for the reply, I still have the original battery. Seems strange that it only does it with hot starts.
Old Jun 24, 2018 | 10:14 PM
rkj427's Avatar
rkj427
Pro Mechanic
Draws more amps when warm or hot than cold...……….. more load, and possibly not enough in the battery to crank it over at normal speeds
Old Jun 25, 2018 | 12:15 PM
sdetro's Avatar
sdetro
5th Gear
I will start with a new battery and see if that cures the problem. Thanks again for the input.
To 427 Convertible hot start starter issues
