Passenger side window problems
Old Jun 25, 2018 | 12:28 PM
Xpensive1's Avatar
Xpensive1
2nd Gear
Default Passenger side window problems
I have a 2005 coupe and recently it has been making a clicking noise in the footwell area (passenger side) as well as the passenger window just moving by its self it goes up and down a bit rapidly and repeatedly during the time that it does it i have no control over the window. I have tried to stop it with the window button but it does nothing. Because of this my batter has been draining and have found the car unable to start if i leave it for more the a day.
Old Jun 25, 2018 | 12:38 PM
EVRose's Avatar
EVRose
A dirty or corroded door switch can cause this problem. As a test swap the door pad switch from the passenger side over to the driver side and see what happens. If the problem follows the switch then you need to clean the switch contact area.
Old Jun 25, 2018 | 04:49 PM
HK770's Avatar
HK770
Have this in favorites. Only for problem info ....not warranty info !!!!!!!!!!
EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, ContiEI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary)
Models: 2007-2008 Cadillac XLR
2007-2008 Chevrolet Corvette
________________________________________ ____________________________________
This bulletin is being updated to end the need for diagnostic information and to provide field fix information.
Please discard Corporate Bulletin Number 08-08-64-001 (Section 08 — Body and Accessories).
Condition
Some customers may bring their vehicles into the dealership for a concern relating to the operation of their power windows.
Correction
Diagnose the exterior door handle switch as a possible cause for this condition. If diagnosis confirms the condition is caused by the exterior door handle
switch, replace both driver and passenger switches. Be sure to mark which switch comes from the driver and passenger doors. Parts will be requested
back through the Warranty Parts Center return process.
Parts Information
Part Number Description
10446243 Front Side Door Handle Switch
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
N9588* Front Side Door Handle Switch — Replace (Both) 0.9 hr
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
To Passenger side window problems
