Fuel Door Actuator problem
Old Jun 26, 2018 | 10:41 AM
twister1442's Avatar
twister1442
Default Fuel Door Actuator problem
'05 Coupe Base with a fuel door release that sticks open. I can wiggle it out and I blew it out with compressed air and sprayed some liquid lubricant in it, bit it still sticks on occasion and if I hit a bump the fuel door will open. Any recommendations? What about graphite? Do I just need the whole new assembly? When I press the button the release moves like it's supposed to, but when I physically move it back and forth, it feels coarse.
Old Jun 26, 2018 | 02:46 PM
twister1442
Thanks! Read all of the threads you posted and I think I'll be replacing the plunger spring. You guys are great! Thanks, again!
Old Jun 28, 2018 | 11:53 AM
DEV-06C6's Avatar
DEV-06C6
Right, just replace the spring. I bought a stainless steel one from a hardware store. Very simple job.
Old May 4, 2019 | 12:24 PM
LiLi's Avatar
LiLi
I have the same "sticking" as the fuel door (gas cap) will not release. Do I have to take the wheel off and everything to fix this or can I do it from above? So far, everything I have read is that it would need to be replaced. I am hoping there is an easier fix. Thanks!
To Fuel Door Actuator problem
