BTR Stage 2 cam surging
Old Jul 11, 2018 | 10:05 PM
Panterawill's Avatar
Panterawill
Default BTR Stage 2 cam surging
Should I be experiencing surging with a BTR Stg 2 cam??
Old Jul 12, 2018 | 12:17 AM
UH-60DRIVER's Avatar
UH-60DRIVER
Absolutely not! You need a better tuner
Old Jul 12, 2018 | 08:11 AM
Must_Have_Z's Avatar
Must_Have_Z
"Should" you? Depends on the tune and other mods.
"Could" you? Absolutely YES. Every aftermarket cam has the potential to surge in certain scenarios.
I have a custom cam very similar in specs to the BTR 2. If my spidey senses are really on point, there are times (very infrequent) where I can feel the slightest/tiniest surge when my car is set on cruise and the car is at low RPMs (1500-1600). It's so faint you can't really feel it if you're not "trying" really hard to detect it.
Bottom line, even with a perfect tune your car may ever-so-slightly surge in rare situations.
Old Jul 12, 2018 | 08:44 AM
Panterawill
I have significant surging at 1500-1700
Old Jul 12, 2018 | 11:30 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
How much overlap?
Old Jul 12, 2018 | 02:27 PM
doomi's Avatar
doomi
Originally Posted by jim2092
How much overlap?
5.5 if I remember correctly.
OP, I run a BTR stage 2 on my LS3 and don't have bucking like it sounds like you have. It will occasionally surge lightly if I'm in a high gear decelerating at very low RPM, but that's it.
Old Jul 12, 2018 | 05:30 PM
Ragtop 99's Avatar
Ragtop 99
In 6th gear there should not be much surge at 1500 rpm, and none by 1,700 rpm for a cam with 5.5* of overlap if the tuner works at it. In 1st gear, where the load is light, some surge at 1500 rpm is not surprising.
Old Jul 13, 2018 | 11:23 AM
4drtrg's Avatar
4drtrg
http://www.tuningbyshanehinds.com/
got my car running via remote tune runnin like a top. My cams bigger and drives very tolerable for how big it is in all fairness lol
Old Jul 13, 2018 | 06:35 PM
jaybee924's Avatar
jaybee924
You guys with the BTR Stage 2 how much rwhp are y'all making with supporting mods?
Old Jul 13, 2018 | 07:06 PM
doomi's Avatar
doomi
I'm at 468 rwhp in my LS3.
Intake, headers, ported throttle body, exhaust with no cats and BTR stage 2.
Old Jul 15, 2018 | 09:06 PM
KW Baraka's Avatar
KW Baraka
No....you shouldn't.
KW
Old Jul 16, 2018 | 11:08 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
O2 sensor has no control over the throttle whatsoever.
Likely min airflow is set a little too high.
Old Jul 16, 2018 | 11:36 AM
Must_Have_Z
556/485 on my Z06 with supporting mods (intake, CAI, headers)
To BTR Stage 2 cam surging
