Issues pumping gas
Old Aug 4, 2018 | 12:24 AM
JetstreamGS's Avatar
JetstreamGS
Default Issues pumping gas
While filling up the last few times, the pump would stop prematurely making it a pita to fill up. If I pressed the handle more then half way it seemed the pump would randomly cut off. What's causing this? Common issue? Thanks folks?
Old Aug 4, 2018 | 12:44 AM
jfrancis062's Avatar
jfrancis062
Cruising
I've been having trouble too. I just got mine and it's been like that ever since. I'm sure it's not normal and I thought I read a post on here before about it. I'll keep searching and let know if I find it.
Old Aug 4, 2018 | 07:10 AM
Richard G.'s Avatar
Richard G.
Default No problem so far
I have had my C6 for 4 years now. Because of the two tanks, I put the pump on slow feed and let the pump shut
off the fuel flow. I have never had a problem with mine. Maybe try another gas station or go slow on the fuel delivery.
Old Aug 4, 2018 | 09:00 AM
Dano523's Avatar
Dano523
Keep the back of the gas pump nozzle hose section pointed at the back car (nozzle sideways), and when the nozzle kicks off, the tanks will be full.
Old Aug 4, 2018 | 09:02 AM
Dave S's Avatar
Dave S
Retired & lovin' it!
Depending upon the flow rate from a particular station pump, fuel may flow faster than the crossover pipe between the tanks can handle, resulting in a back-flow & shut-off. Set the fuel nozzle at the half way point & you shouldn't have a problem although yes, it will take a bit longer to fill the tank(s).
Old Aug 4, 2018 | 02:35 PM
Dano523's Avatar
Dano523
Not really a flow rate of the pump probem, the direction that the fuel is sent down the fill hose to the tank isntead.
Hence with the nozzle pointed down into the fill part of the tank like you normally fill a car, this creates a splash wave of fuel in the drivers tank once it filled up first, and causes problems with the fuel flowing cleanly to the passengers tank through the cross over tube instead.
So the pump nozzle is not held like the below photo to fill the car, but rotated 90 degrees counter clockwise so the hose part is facing the back of the car.
Old Aug 4, 2018 | 04:49 PM
EVRose's Avatar
EVRose
^^^ This works. ^^^
Old Aug 5, 2018 | 10:27 AM
JetstreamGS
Thanks Dano, I'll try that next time.
Old Oct 9, 2018 | 11:48 PM
JetstreamGS
I am pleased to say that Dano's method works! Pump no longer shuts off prematurely. Thanks again Dano!
Old Oct 11, 2018 | 02:35 PM
PDsVettes's Avatar
PDsVettes
I just put the nozzle in, set the auto feature to max, and let it fill up and cut-off. Never a problem and get a complete fill-up. Is this just a problem for some cars? If it is, logic would say that there is something amiss in these cars or everyone would have this problem. I've made several road trips using different gas brands and no problem.
Old Oct 11, 2018 | 05:53 PM
deriley's Avatar
deriley
Veteran: National Guard
The hose in the fill neck gets a kink in it remove enter fender well put hose clamp on it to straightened out kink.
Old Oct 14, 2018 | 12:53 AM
Cherokee Nation's Avatar
Cherokee Nation
Originally Posted by PDsVettes
I just put the nozzle in, set the auto feature to max, and let it fill up and cut-off. Never a problem and get a complete fill-up. Is this just a problem for some cars? If it is, logic would say that th is something amiss in these cars or everyone would have this problemere. I've made several road trips using different gas brands and no problem.
Same here...I put the nozzle in the way it should be and never had a problem.
Old Oct 14, 2018 | 01:30 AM
HOXXOH's Avatar
HOXXOH
I just set the nozzle on the low notch. It takes a little longer to fill, which gives me time to clean windows and check out the babes at the gas station.
Old Oct 16, 2018 | 02:14 PM
koreanbeefcake's Avatar
koreanbeefcake
i noticed the fuel spills out if i let it go on full. I hold it full for half, then finish at the low speed.
To Issues pumping gas
