2012 Grand Sport automatic with 16k miles.
At low speed there is a metallic sound like lightly striking a pipe. It sounds like a half shaft or drive shaft, however, that is generally more of a "clunk" . It started as a once in a while thing, it is doing it constantly now at low speed as you are ever so slightly on/off the throttle. Corvette tech inspected all U joints and said this may be "normal" with some wear and tear. Nothing loose. It this something common to others. It is very aggravating and a bit disconcerting as these cars are not meant to be babied.
