Help me understand fan module testing
I supplied 12v directly to fans. Fan turns on
I tested for 12 volts at the chassis connector. 12v present
I commaded fans on with hptuners after hard wired connections. Nothing.
I installed a test lamp between the positive wire on the chassis connector to the trigger wire and commanded fans on from zero to 100% and nothing.
I installed a test lamp between the positive and negative on the chassis connector and test lamp illuminated.
With these tests done i believe the ecm is bad because it is not sending a signal down the trigger wire.
Any other test i can do?
Also does the command fan on function work in hptuners. Ive never used it before but i believe it should work or it wouldnt be there.
The ECM controls the PWM via the modulation grounding on the Rd/OG wire on ECM 58, and not by sending power on that wire to the PWM isntead.
So if you have power and ground to the PWM, the fan will run when it sees direct power, then 12v test light to pieces the shielding on the PWM RD/OR connector wire to get a wire connection from the test light and touch the probe on the test light to ground to supply a ground to the control wire.
If fan runs with control wire grounded, then problem is control wire back to the ecm through the two connector and pins pointed out above.
Also, if the car has been turned, there are a number of factors in the Tune that will tune the fan off even if the motor is hot. The quick check to see if the ECM is really controlling the PWM, it to start the car, and turn the A/C. Here there is a setting in the tune that will turn the fan off from A/C turn-on command, but most tuners will not go near that specific setting most of the time instead.
C186 connector is next to the the battery on a wet sump motor on the fender wall (about half way up the side of the battery), and C182 is by the ECM itself.
http://garage.grumpysperformance.com...nds-etc.10092/
Cooling wiring schematic if you need it,
http://www.mediafire.com/file/0vzf5b...g%20wiring.pdf
Hence in control circut's 101, using the ground side for modulation or breaking the circuit, not the positive side, ends up with a lot less RF noise as the module switches on and off.
The HVAV blower motor works the same way through the HVAC controller.
Down load the one liner PDF I linked below and take at the ECM control wire. It shows that it providing pulsing grounding to the control wire back to the PWM, not positive instead,
I am still confused on how the fans work but i cant get the test lamp to light up. I have a trouble ticket in with hptuners to see if they have a fix for my mpvi pro not commanding the fans on
