C6 Battery terminal replacement
Old Sep 13, 2018 | 11:36 AM
VETYGUD's Avatar
VETYGUD
Default C6 Battery terminal replacement
Broken positive terminal oval lug
Super Start brass marine terminals with ss washer nuts
OEM terminal cut down & attached to marine battery terminal
Both + and - battery terminals replaced
While getting ready for a trip I checked my battery cables on my 2009 vert to find that the positive battery cable terminal was loose. I observed that the oval clamp down lug was broken. After reading about the OEM battery terminal design and multiple complaints about this condition I was not going to pay the $165.00 GM retail price to replace the cable only to have the potential of the terminal breaking again. The new OEM GM cables would have to be removed and reinstalled to the starter and other locations on the underside of the vehicle.
I purchased a set of Super Start brass marine battery terminals from a local O'Reilly Auto Parts for $5.99. I removed the two wing nuts and used 5/16" stainless steel hex nuts with attached star washers.
I cut off the ends of the OEM terminals just behind the battery post holes with a Dremel tool with an abrasive cutting wheel. You need to leave enough of the terminal to drill a 5/16" hole and form it into a large electrical spade.
The formed spade on the cable end can now be attached to the brass marine terminal 5/16" threaded stud with the SS hex nut with star washer and tightened.
The battery cable terminals can be attached to the battery posts and clamped tight.
This takes approximately 1/2 hour and works best if you remove the battery while cutting the OEM battery cable terminals down.
The advantage of using the brass is for better corrosion control. The cables are not shortened which would happen if you completely cut the cables and crimped new terminals on. The red protective positive cable cover will cover the new clamp terminal. If you need to add any additional wires for accessories now you have a stud to attach them to. The new clamps can now be removed multiple times without the possibility of them breaking like the OEM terminals. This is a quick, inexpensive and easy fix and IMO better then the OEM terminals. I spent $8.19 total for this fix.
Old Sep 13, 2018 | 02:13 PM
theandrewo's Avatar
theandrewo
Nice work! I'll probably do the same now.
Old Dec 28, 2019 | 11:03 AM
Fountain chuck's Avatar
Fountain chuck
Cruising
Just found this same problem on my c6 Z. No way to tighten the battery cable ends down and not getting a good enough connection. Going to do this same mod👍🏻
Old Dec 29, 2019 | 10:31 AM
new 2 me's Avatar
new 2 me
Nice repair
Old Dec 29, 2019 | 02:45 PM
05 Wreck's Avatar
05 Wreck
Originally Posted by new 2 me
Nice repair
^+1, also the red and black GM terminal covers are easily torn and this repair provides easy replacemnt.
Old Dec 30, 2019 | 10:36 AM
Red06Vette's Avatar
Red06Vette
I've found these work quite well, very solid connections. Available in various sizes.
https://www.remybattery.com/cable-co...onnectors.html
Old Dec 30, 2019 | 11:26 AM
maverickmk's Avatar
maverickmk
Wow, those are nice. I'll be doing this real soon.
Old Dec 31, 2019 | 10:01 AM
Fly N Low's Avatar
Fly N Low
Those terminals look nice do you know what gauge wire the 05 C6 has?
Old Jan 2, 2020 | 11:30 AM
Red06Vette's Avatar
Red06Vette
I believe the wire is 4 gauge, should be written on the wire somewhere.
Old Jan 9, 2020 | 11:33 PM
TomdaToolman's Avatar
TomdaToolman
I ordered a set of these made by Detrit Speed. They're solid brass w/ nickel plating.$21.00 plus shipping from Amazon. Not Elgible for Amazon Prime, unfortunately.
Old Jan 10, 2020 | 08:45 AM
BadAV's Avatar
BadAV
That's a GREAT find! I wish I had seen this before I replaced the lug connector on my John Deere tractor last week. I don't have large crimpers so I used a small butane torch to solder the lug in place.
Old Jan 10, 2020 | 09:07 AM
maverickmk's Avatar
maverickmk
Link if anyone is interested:
https://www.amazon.com/Detroit-Speed-Top-Mount-Terminals-Application/dp/B07L7CN669/ref=sr_1_1?keywords=detroit+speed+battery&qid=1578665205&sr=8-1 https://www.amazon.com/Detroit-Speed-Top-Mount-Terminals-Application/dp/B07L7CN669/ref=sr_1_1?keywords=detroit+speed+battery&qid=1578665205&sr=8-1
Old Sep 14, 2020 | 09:05 PM
FlyBono24's Avatar
FlyBono24
Nice! I just took my car in for the battery draining, and they wanted to replace the entire battery cable and charge like $550!
I spoke directly with the mechanic and he was like... nah, you just need to replace the terminal, the connection is loose and not making a good connection so it's draining.
So it's just a bad design on the OEM terminals, huh? I'm looking at those Detroit Speed ones.
Old Sep 15, 2020 | 01:23 AM
FlyBono24's Avatar
FlyBono24
Originally Posted by maverickmk
$21 for the part and $10 for shipping? Screw that...
Old Oct 11, 2020 | 01:16 PM
Slackmaster007's Avatar
Slackmaster007
Cruising
Those Remys look great. What gauge size did you use? And did you get straight terminals or use left and rights?
Old Oct 11, 2020 | 01:26 PM
LightningBrett's Avatar
LightningBrett
I had weird electrical issues now and then. Absolutely amazing what a new battery and new Tight cable ends will do for ya!
Old Sep 8, 2021 | 10:04 PM
vettelover8306's Avatar
vettelover8306
I'm super late in here but yes unbelievable how brand new terminals and cables change everything in vettes ... C6 s need a special electric attention ... Good battery...clean grounds ...strong cables and good to go
To C6 Battery terminal replacement
Old Jun 24, 2024 | 11:02 AM
Jupiter81's Avatar
Jupiter81
Welp after installing the 170mechman, new accessories belt, new battery was getting really low valtage still.
ordered the sac city corvette big 3 upgrade and some tightening of a few things and the car now maintaining 14.4~14.6 after heat soaked with A/C blasting, radio up, lights and whatever other load I can put on it.
I was skeptical about the big 3 but it surely helped, when cool the car starts and idles at 14.7 so if you’re having low voltage issues then get big 3 upgrade from saccitycorvette, so easy a caveman can do it
Old Jun 25, 2024 | 08:13 AM
robert.m.kalis's Avatar
robert.m.kalis
I found that the stock battery terminals actually work ok for me if I to push down hard on them while tightening the nut. Otherwise, because the battery posts and terminals have a tapered (conical) shape, their tendency is to move away from each other when tightened, causing a loose condition.
I do agree the design is half baked
Old Mar 31, 2026 | 03:46 PM
Rob Via's Avatar
Rob Via
I am in the same boat and looking for a good alternative. If anyone have done other solutions, I would like to see them.
