Help and Tips! First time to the drag strip with my 09 Z06
Hey Guys, I just bought a new-for-me 2009 Z06 a few weeks ago. My brother in-law has a Hellcat Challanger and we decided a friendly Friday night drag race is in order.
My car as a Halltech CIA and cat-back exhaust. Other than that its stock with Michelin PSS tires (325/30R19) rear.
So we will be doing the Friday Night street drags at our local track next week. I have been to the drag strip a few times in the past but my drag racing experience is very limited so looking for some helpful tips and advise:
Here are my questions:
Should I drive through the burn-out box or go around the water? Wet or dry burnout?
What RPM should I launch at?
What tire pressure should I run (cold)?
Any free things I could change/check to help? Spark plug gap for instance?
Any other tips are welcome! Thanks guys!
k.miller959 (09-16-2018)
Received 2,061 Likes
Turn TC off and leave the other nannies alone. Drive around the water box and just spin the tires a couple revolutions to clean off any dirt. No burnout. Watch the car in front of you. If he has slicks/DR's and has a straight launch,follow in his tire tracks, otherwise find a different line. Don't just dump the clutch and stand on it, but try to match your clutch release with the power just like you do at every stoplight, only quicker.
Most of all, remember to abort any run where you get wheel hop, excessive spinning, missed shifts, or anything else that is not in a dead straight line to the finish. It's far better to bail out from a bad start and return to try again, than break parts or hit walls. Pay close attention to what you do and you will learn from the little mistakes, because no one is even close to good at first. It's a work in process.
Have fun and play safe.
The following 2 users liked this post by HOXXOH:
GS60th#47 (09-16-2018),
Stock heads and you're gonna be bangin' gears at the strip? You know about these cars right?
So I ran across this in my searching. It seems to have most all the info I was looking for. I think I read this guy was on this forum so I am sure it has been posted here before but in case anyone else is looking for it, then here it is. I knew this was out there just had to find it lol. I'm a bit late to the table.
http://www.superchevy.com/how-to/cor...eleration-pt2/
http://www.rangeracceleration.com/Launch_Tips.html
Google: Ranger c6 z06 drag racing. He made a bunch of very informative drag racing videos with stock and lightly modified Corvettes. He holds a few records...
Testing on the street beats up the equipment for no reason, the drag strip's prep'ed surface is completely different, and requires different techniques.
Just like said above, don't just hammer down and dump the clutch on take off, the half shafts or the rear diff is the weak link. Absolutely shut it down and try again on another pass if your rear wheels start hopping.
We have Friday nights "Run watcha Brung" at Royal Purple race track here in Houston, be careful about the launch pad being very sticky due to the VHT - it's a lot better to launch out like said above like a hard traffic light start - get out 10-20' and then hammer down on it.
Don't ask me how I know, sat there recording my son at the tree, told him everything above and he launched hard and rolled probably about 50 - 100' out. Have to say the car now has a RPM Stage 4 rear end.....after being pushed out of the way and put on a transport back to home. Don't even get me started about the bitching I heard from his mom...lmao!!
Yikes! This thread is definitely not a good sales ad for the Corvette from a durability standpoint...apparently I am going to drop a valve and shatter the rear end if I take it to the strip lol.
Go out have fun, I just wanted to let you know what my first experience with my son behind the wheel was........LOL
k.miller959 (09-18-2018)
