Exhaust manifold help please
Old Sep 15, 2018 | 06:17 PM
etazbaz's Avatar
etazbaz
Default Exhaust manifold help please
i need help. I have a rounded bolt head from the cat to the exhaust manifold. I cannot get a vice grip on the bolt because of its location. Tried to pull the manifold with cat from the top. Removed alternator, valve cover and disconnected steering column from steering box. Cannot figure out how to detach the upper steering column. There is a boot to the firewall.
Old Sep 15, 2018 | 11:30 PM
etazbaz's Avatar
etazbaz
Never mind. I figured out a solution that might be helpful to others. I used a cutting wheel to cut the stud so that I could use a nut extractor to get the nut. Took about an hour to cut the stud off because of my smallish compressor but once the stud was cut it took only a minute to get the nut off. Now I wait for the Kooks to arrive.
