Help with Spark Plug Heat Range
Old Oct 5, 2018 | 07:46 PM
Janderson8903's Avatar
Janderson8903
Default Help with Spark Plug Heat Range
Hey guys, reaching out with a question that I can't seem to find the answer for from the forums yet. Suggestions would help. I haven't contacted any vendors yet. Looking to figure out suggestions for a good spark plug and the heat range I need. Currently have NGK TR6 that came with my a&a kit. I'm getting the service charging system message on and figured it couldn't hurt to change plugs because I've read of a few people having the same issue.
Car is a 2007 Z06 with 52k miles
Here's the mods that relate:
Comp cams LS7R cam (N/A cam)
PRC 285cc heads
Kooks 2" long tubes
A&A kit Ti trim V3 with 4 inch pulley
dewitts cutdown radiator
Lingenfelter 2 step. Set at 3500 on switch and 6900 as new redline.
Kenne Bell BAP
Alky Control methanol kit that comes in around 4 lbs boost
That's everything that I think relates but I may be leaving something out. It made 690 rwhp on 5.5 lbs of boost. Let me know what you suggest. Thanks guys.
Josh
Old Oct 5, 2018 | 10:44 PM
irok's Avatar
irok
Default this
PRC 285cc heads
Kooks 2" long tubes
Kenne Bell BAP
Josh
use the factory 2009-2013 ZR1 iridium plugs gapped at .028.Its what I use with my V3 with methanol.never an issue with them in the 3 years they have been in the car
