Transmission
Old Oct 8, 2018 | 06:54 PM
crank grinder's Avatar
crank grinder
Default Transmission
where is the manual transmission oil cooler pump.I have a bad transmission leak and I heard if you drove the car aggressively before the leak that could be the problem. Who drives there corvette aggressively?
Old Oct 8, 2018 | 09:29 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Pump is on the front of the transmission (rear of the car)
Old Oct 13, 2018 | 11:41 PM
Dano523's Avatar
Dano523
Yep, pump in on the front of the trans, under the input shaft on the bottom side of the front face of trans, and you have to remove the trans from the car (away from the back of the torque tube since it rear bell part covers it) to get to it.
To Transmission
