HUD Install
Old Oct 10, 2018 | 11:28 AM
Bradlee2010's Avatar
Bradlee2010
Default HUD Install
I just bought a 2008 base model C6, and it doesn't have the HUD option. has anyone installed a HUD on a car that did not have one? If so how difficult was it?
Thanks in advance!
Old Oct 10, 2018 | 11:56 AM
dforesi's Avatar
dforesi
It can be done for $500 with new parts
https://www.corvettemods.com/C6-Corv...saAlZoEALw_wcB
I would search. There are videos on youtube of people doing the install.
Old Oct 10, 2018 | 04:07 PM
PCMusicGuy's Avatar
PCMusicGuy
I did it quite a while back before it was a thing. If you search around different vendor sites you can find the "kit" of parts you will need plus the harness for around $400. If you get used working parts you could do it cheaper.
If you are willing to cut your A/C duct that goes over your instrument cluster to the driver's side vent, it is a fairly easy install. This is the route most people take and they put the duct back together with the foil tape they use in attic ducting. This is the method I would do if I could do it over again. I pulled the entire dash and it was an all day affair never having done anything like that before.
If you end up doing this yourself and want a hand, let me know.
Old Oct 10, 2018 | 05:22 PM
timd38's Avatar
timd38
Took about 3 hours in my garage and we didn't cut any ventilation ducts. Just follow the instruction and don't try taking short cuts.
I bought my kit from Gene Culley.
https://www.cultragfactoryparts.com/
Old Oct 12, 2018 | 12:37 AM
SilverC54me's Avatar
SilverC54me
Do the job correctly. Remove the dash to change the bezel and don't cut the AC duct. Also there is some wire splicing that will need to be done and that is easier with the dash out.
Gary
To HUD Install
