C6 "Heads"
Old Oct 15, 2018 | 12:52 PM
legrand88's Avatar
legrand88
Default C6 "Heads"
Have just sold my C2 and am looking at the C6 as a replacement. A lot of the ads I've read mentioned "head/valve issues addressed" - what are they referring to ? - Thanks for your feedback - Brian
Old Oct 15, 2018 | 01:03 PM
eckseleven's Avatar
eckseleven
It is an issue unique to the LS7 powered cars. If you would be getting a base, Grand Sport or ZR1, you'd have nothing to worry about.
Edit: misread what you wrote. Sounds like you are looking at Z06 ads. Search the forum for LS7 valve issue and you will find a lot of information. The good news is if you've found cars that have it addressed, you shouldn't have anything to worry about.
Old Oct 15, 2018 | 01:07 PM
KW Baraka's Avatar
KW Baraka
Valve guides.....
KW
Old Oct 15, 2018 | 04:42 PM
Orion2011's Avatar
Orion2011
Only an issue on the ZO6 cars like eckseleven said earlier.
EDIT: the after cat O2's are there only to check the status of the cat. They are not used for determining mixture.
To C6 "Heads"
