I done messed up... I need some help...
Old Oct 22, 2018 | 12:03 AM
bringit665's Avatar
bringit665
Default I done messed up... I need some help...
I was in a rush for no reason and I needed to jump my 2005 Vette. Well I put the jumper cables on the wrong terminals, no I have absolutely no power to the car. and there was a awful smell coming from the cabin and from the engine bay. I checked every single fuse, no fuses are busted. I'm not sure how to check the relays on the fuse boxes. I haven't checked the computer in the car. after I checked the fuses I decided to try to jump it one last time. I hooked up my cables to my other car then I put the positive on the correct post then I touched the negative wire and it sparked pretty bad. I am taking my battery in tomorrow to get it checked.
Is there anyone that could possibly tell me what could be wrong?
Old Oct 22, 2018 | 11:02 AM
RicK T's Avatar
RicK T
Well, there are many possibilities. Let's hope the various fuses and fusible links saved you from a real catastrophe.
Rather than regurgitate a bunch of info, I suggest you thoroughly read and understand this discussion and hope you are as lucky as the original poster of the discussion was. Good luck and please let us know the details of what you find. It may help someone in the future.
https://www.corvetteforum.com/forums...-to-start.html
Old Oct 22, 2018 | 11:27 AM
Sergio8A's Avatar
Sergio8A
Sounds like you fried your ECM. Get access to it or remove your ECM and see if the smell is coming from the module itself .
Old Oct 22, 2018 | 12:59 PM
bringit665's Avatar
bringit665
Thanks for the thread! I am going to take off my alternator to test it out at a local place. I will keep this thread updated.
Old Oct 22, 2018 | 01:01 PM
bringit665's Avatar
bringit665
That's the last thing I need... I'm worried its both the EMC and the BMC.
Old Oct 22, 2018 | 01:04 PM
bringit665's Avatar
bringit665
Does anyone know where the "main fuse" is? I've been trying to search it up but I haven't found anything yet.
Old Oct 22, 2018 | 04:34 PM
bringit665's Avatar
bringit665
Update: I took off my alternator to test it at a local shop. The alternator tested 'Good' so another piece of the puzzle is done. I am now going to check the ECM to see if that got burnt. I will be getting my battery back tomorrow after a full day of charge.
Old Oct 22, 2018 | 10:16 PM
TTZ06VETTE's Avatar
TTZ06VETTE
Is there a fusible link on the car? They are meant to break when that happens.
Old Oct 23, 2018 | 12:05 AM
bringit665's Avatar
bringit665
I read that it was located by the starter. I checked that earlier today and didn't see anything. But I will check again tomorrow.
Update: I checked my ECM as well. I did not see any signs of being fried; there wasn't a smell in any of the electronics in that area.
Old Oct 23, 2018 | 11:00 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
There are two diodes listed at the bottom of this page.. I'm not sure where they are but I'd start by seeing if you can locate those
https://www.autogenius.info/chevrole...e-box-diagram/
Old Oct 23, 2018 | 01:07 PM
bringit665's Avatar
bringit665
Update: So this morning I woke to get my battery from the local advance auto parts. The battery was still good. I went back to my car and put the battery in, the car started! This made my entire day, now I can focus on my exams this week. On the down side my Bose speaker amplifier is fried. But that's okay, I rather have that gone then my entire electrical system.
Old Nov 7, 2018 | 01:11 PM
mn_vette's Avatar
mn_vette
All Electronic Control Units on modern vehicles are required to pass a Reverse Battery Test. Basically is someone installing the battery is not paying attention and hooks it up backwards they don't want it to blow every ECU in the vehicle. You went from a little positive to very negative very quickly with the jumper instead of no voltage to negative. I'm still surprised anything blew, but luckily it was only the amp.
Old Nov 9, 2018 | 08:10 PM
Ahrmike's Avatar
Ahrmike
Good time to upgrade your setup. Bose amp sucks for upgrading because it takes the audio signal and filters to front "subs" so you cant swap them out for 6.5"s if you want to do an external sub.
To I done messed up... I need some help...
