RXT and Tick master will it work?
Old Oct 25, 2018 | 11:02 PM
LSXvnm's Avatar
LSXvnm
Default RXT and Tick master will it work?
I just ordered a McLeod rxt twin disc and tick master cylinder with the line that goes all the way to the slave. Then I started reading on the form seeing where the Tick master supposedly won't work with the RXT clutch. Is this true or is McCloud saying this just to cover their ***?
Old Oct 26, 2018 | 05:41 AM
jaybee924's Avatar
jaybee924
I'm sure it will work but most of the clutch makers make their clutch to work with the stock hydraulics. Because it could be a problem with engaging or disengaging or anything else can go wrong. Playing devils advocate just say the clutch did mess up and your running a tick master and call McLeod. An tell them your not running stock hydraulics I know what they would say it's the master cylinder. But also what if it was because the master cylinder the clutch messed up your going to blame McLeod. So I guess you can say they are covering their *** but this day in time you have too. I wouldn't want to get a bad reputation for my product if someone put a different variable in there but nobody ain't going to say they added that different/aftermarket variable also. We as people go off feedback and most of the time people leave the need to knows out or all the details out. Sorry for beating a dead horse to death. I have my stock clutch and hydraulics in my 2011 C6 GS so I'm not bias. LoL
Old Oct 26, 2018 | 07:21 PM
lght spd's Avatar
lght spd
The pressure plate is designed with the travel requirements of the factory master cylinder and internal slave cylinder. The Tick master is a larger design at 7/8" bore. This size bore will over travel the pressure plate finger and cause the pressure plate past the apex of its release point and it will actually re-engage on itself. Thus cause the clutch to slip, generate more heat and pre-maturely burn the discs up. These issues are eliminated when using a factory spec master cylinder and slave cylinder.
Old Oct 26, 2018 | 07:25 PM
LSXvnm's Avatar
LSXvnm
I believe I read somewhere that tick sells a smaller bore Master? Could I get this and it work? if not it sounds like I need to return this master cylinder and buy a new OEM
Old Oct 26, 2018 | 09:54 PM
lght spd's Avatar
lght spd
If Tick offers a 3/4” bore option then you’d be good to go!
Old Dec 9, 2018 | 12:23 PM
LSXvnm's Avatar
LSXvnm
Update I installed the rxt with stock slave, master, and line and everything works fine
To RXT and Tick master will it work?
