Exhaust Z06
Old Nov 3, 2018 | 09:23 AM
HT1663WB's Avatar
HT1663WB
Default Exhaust Z06
I'm new to the C6 Z06. I have a 2008 Z06 with 26k on it. When running in the garage the exhaust fumes are really bad. My C5 Z06 doesn't smell like that. Door is open of course. Does the C6 Z run really rich? As far as I know it's bone stock right down to the air filter. Thanks, Bill
Old Nov 3, 2018 | 03:36 PM
farmington's Avatar
farmington
If you still have cats, they probably have been knocked out internally.
Old Nov 3, 2018 | 03:55 PM
HT1663WB's Avatar
HT1663WB
Originally Posted by farmington
If you still have catds, they probably have been knocked out internally.
I still have them. The Z is quiet and there is no tune
Old Nov 3, 2018 | 05:09 PM
farmington's Avatar
farmington
Someone probably knocked the insides of the cats out to possibly make more power
Old Nov 4, 2018 | 10:47 AM
HT1663WB's Avatar
HT1663WB
Wouldn't the check engine light come on?
Old Nov 4, 2018 | 03:14 PM
Mike's LS3's Avatar
Mike's LS3
Sounds like someone gutted the catalytic converters, then most likely the tune was adjusted for the CEL.
Old Nov 4, 2018 | 07:27 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Agree with previous. It's VERY easy to get around the light coming on.
I run Z06 cats on mine just so I DON'T have smells.. something isn't right.
Old Nov 4, 2018 | 07:45 PM
HT1663WB's Avatar
HT1663WB
It passed inspection so I guess it's ok. Thanks for the replies
Old Nov 4, 2018 | 08:07 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Does your state require an actual sniffer or just plugging into the OBD port?
Old Nov 4, 2018 | 09:34 PM
HT1663WB's Avatar
HT1663WB
just the OBD port.
Old Nov 5, 2018 | 02:30 PM
MTPZ06's Avatar
MTPZ06
C6Z's are tuned from the factory to be on the rich side, but we're talking WOT AFR's. As for cold startups, sure its going to be a little rich. If you just got done driving your car around for a sustained period of time and then pull into the garage...you shouldn't have a strong exhaust fume smell. Cold start idling in my garage though...I'd say my C6Z is more odorous than my C5Z was as well.
To Exhaust Z06
