Wanted to get some info on a 05 manual transmission swap. Blew the transmission on an 05 and output shaft broke. I found a 08 manual transmission.
Not sure on a few things.
1st, will an 08 trans work with an 05 diff without an adaptor? If I decide to swap both the trans and diff will the axles line up.?
Any other info on this swap would be very helpful.
thank you in advance
