07 needs rod/main bearings. Help!
Old Dec 3, 2018 | 06:44 PM
MilstarVette's Avatar
MilstarVette
8th Gear
Default 07 needs rod/main bearings. Help!
My 07 Coupe A6 I bought new, has 65K on it and needs rod bearings apparently. It will start for three seconds and is very noisy. Its at a shop that won't do this type of heavy line work. I need recommendations badly on what to do/where to take it/good mechanic that won't overcharge me. I'm in south Orange County so a shop anywhere in LA or OC would work. I do not have the money to buy a new engine for it.
Old Dec 3, 2018 | 11:50 PM
DSOMC6's Avatar
DSOMC6
What shop is your car currently sitting in? I'm in S OC as well. Are you certain the engine doesn't just have a failed lifter versus rod bearing? My 06 LS2 had a lifter go south at 60k miles and it sounded like marbles banging around in a coffee can as well as oil pressure fluctuating wildly.
Old Dec 4, 2018 | 01:07 PM
demon340's Avatar
demon340
What do you mean by" it will start for 3 seconds and is very noisy"?? Does it have good oil pressure?? Does it idle?? Did you check your torque converter bolts??
Old Dec 4, 2018 | 01:24 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Need more info. Main/rod bearings are a very rare failure on these engines, especially stock.
Old Dec 4, 2018 | 03:26 PM
MilstarVette
8th Gear
The car is at United Automotive Repair in Laguna Hills. Any day now they are going to tell me to pick (tow) the car up and I have no where to take it.
Old Dec 4, 2018 | 03:28 PM
MilstarVette
8th Gear
The mechanic said it is low on oil or has no oil, which I find hard to believe. Wouldn't a warning light come on if no oil pressure? Mechanic said it is very noisy, knocking, and says it sounds like the bottom end.
Old Dec 4, 2018 | 03:31 PM
MilstarVette
8th Gear
No it does not idle more than a couple seconds, as it barely starts. Mechanic did not say if it has oil pressure; re-starting the engine to verify oil pressure might cause more damage, correct?
Old Dec 4, 2018 | 04:32 PM
BigVette427's Avatar
BigVette427
American Heritage Performance in Harbor City, outside of Long Beach. They specialise in Corvette's and are top notch folks to boot. You need search no further!
25901 Belle Porte Ave, Harbor City, CA 90710
https://www.americanheritageperformance.com/
Old Dec 4, 2018 | 09:55 PM
American Heritage's Avatar
American Heritage
Supporting Vendor
Thanks for the recommendation BigVette427!
OP Give us a call
310-326-2399
We are a full in house automotive performance machine shop plus we also do the heavy line work!
https://www.yelp.com/biz/american-he...ce-harbor-city
Old Dec 4, 2018 | 10:13 PM
MilstarVette
8th Gear
Thank you for the recommendation. I called American Heritage Performance, spoke to Jake, and they are going to get back to me as to whether or not they will do the work.I will keep you updated.
Old Dec 5, 2018 | 06:56 PM
MilstarVette
8th Gear
Thank you BigVette427. American Heritage Performance got back to me right away and can do the work. I am making arrangements to have it taken (towed) there shortly.
To 07 needs rod/main bearings. Help!
