When changing the cam I installed a Lingenfelter 160 thermostat. I done this with each of my last 5 vettes and they have always had steady coolant temps around 176-178 while cruising. This one is acting much different and I think it may just be a bad one but want to see if anyone else has encountered this issue. Temps while cruising yesterday in 30 degree weather were 187-195 cruising, and if I held the RPM's around 3K temps temp would drop right down to 178. It almost seems like the thermostat isn't opening enough to move coolant at idle and cruise, but the higher RPM is moving the cool coolant past the thermostat. It's not overheating, just a lot of weird temperature swings. Any ideas?
Stat is fine,
Hence lower stat will help to hold the temp down a touch if your not on the throttle, but as soon as you get on the throttle more, the temp is going to rise upwards to around the 200+ degrees. If your trying to hold the temp at say 180 or below, then will need a better radiator, and fan system that the OEM unit is not up for the task isntead.
As for 160 stat and you driving the car in the cold weather, very, very bad idea. Hence the stat will start to open up at a lower temp, and can cold coolant shock the motor isntead.
Stat is fine,
I think you may have misread my post. The car is not staying cool in the cold weather. It's running low to mid 190's at cruise. When I get on the throttle the temps actually drop, not rise. I've had 5 vettes with a 160 thermostat and they have all stayed right around 180 at cruise and I've also never had an issue driving in cold weather with a 160 thermostat. My guess is that it's not opening at all (or just a little) and the increased RPM's are pushing enough coolant thru the bypass to cool it. I've got a replacement on the way to confirm.
It's normal that the temp drops with higher rpm as coolant circulates faster. Mine does same thing. What you are describing sounds pretty normal to me.
Agreed. It's just that every other 160 thermostat that I've had in an LS engine, the temps have always been around 180 while cruising, not 194. My guess is thermostat isn't opening enough at low rpms to circulate enough.
Usually they either work or do not. It's obviously opening or you would be over hearing. As said I'd check that the rad isn't partially blocked. It's pretty common for debris to block some airflow.
Take t-stat out and check it in a pot of water heating on stove, when I checked my 160 it started to open at just below 160 and didn't fully open till about 172ish.. at 30* ambient your temp should be right near where it opens fully. 30* is cold out!!!
The stat is only to control the low temperature of the engine. If you are running over the temperature of the stat then the cooling system is not fully up to it's job.
I would check the stat in hot water to verify the opening temp. If the water pump is worn / under driven then this will cause it. Also check the return hose to see if it's collapsing.
If you have an insufficient mix of anti-freeze or the radiator cap is not pressurizing the system - then you can get "boiling " near any hot spots which can cause false readings.
Check the out put hose with a digital temperature gauge and verify the actual temps. Also depending on the fans - you may not be pulling enough air. Check the fan voltage at Idle and 1500 rpm. Check the temp of the return hose.
Stats open before the temperature listed. They are usually open fully within 5 to 7 degrees of the listed temp. Thus I would expect a 160 stat to start opening at 155 or so and be fully open by 165. (+/- 5 to 7) most are really close to the listed range.
My truck has a huge radiator - I put it in - it did a lot of heavy towing. With a 180 stat. no load, it runs between 175 and 185 all day long. Which is what I would expect.
Reason: hate auto spell
Agreed. I'm going to pull the stat and check it in hot water to verify when it's opening. The rest of the system worked fine prior to changing the stat which is why I'm leaning towards a bad 160 stat.
Just thought of another possibility that I will be able to confirm once I pull the stat out. I bought the 160 stat, but I guess it's possible that the Lingenfelter 174 degree stat was mispackaged in the 160 box. That would explain why temps are running warmer than I'm used to with a 160
I have one of their 174 degree stats on my desk right now. There are no markings or numbers on it to indicate what temp stat it actually is. The box says it's a 174 degree stat with their part number L31055307.
Thanks. The 160 part number is L31065307. Summit is sending me another 160 so I will compare both to see when they're actually opening. It just dawned on me that could be what the issue is. I actually got a 174 and not the 160 I ordered. Will let you know once I get it and can test both.
I too saw a consistent 178ish* coolant temp with the 160* stat in my LS3. This would be all the time at freeway speed just cruising.
I eventually went to the 180* stat and see 189-194* depending on rpm at cruise. Which I think is perfect with my 4:10 differential set up.
During the winter here in the Bay Area (mild) I was hard pressed to get the coolant to get above 212* wanting the condensation to boil off with the 160*.
My 05 m6 runs exactly the same in colder weather. I run 176-178 sustained highway in warm weather and high 180’s in under 40 deg....I think the car is somehow compensating to allow oil temps to get up. Bothered me too but it’s the way it’s been.
