"C6 from 2005-2010 navigation radio clock stops after battery disconnect
#461
[QUOTE=LMDNC5;1598850508]
The Red slash will go away, Your Nav will still work just No Clock! Needs a Firmware fix. Call Chevy and Bitch! The numbers are just above
One more here but I don't have a working GPS either (red slash)
I got mine to work again by putting in a destination (my home address) I dont know if it helped but i pushed the red and white thing above the red slash symbol and just drove and after about 2 miles the slash mark went away still no clock though
#462
Hallo people
i’m using this forum for a wile for looking stuff up en for information and it is very useful and helpful
so thanks for all the information
And sinds yesterday I have the same issue here
i disconnected the battery to do some maintenance on the car last week.
and yesterday I took it for a ride and noticed that the clock display is empty I tried everything but no luck
so I thought I check the corvette forum seems it to be that I’m not the only one
lets hope General Motors comes with a solution
whis you all a nice Sunday
cheers from the Netherlands
#465
On 12/13/18 a changes must have been made to the satellite communications that disables the clock once the battery is removed. I went into diagnostic mode and it shows the errors began on that date. It seems to only impact the clock. I have a C6 2007 Z51 and found the issue when I changed out the car battery in the first week of Feb 2019. I am calling Chevy Customer support to see if they have found a fix at this time.
#466
#467
Look at walhan_qtr that had all those Vettes go down. Unless our Corvettes are all secretly communicating with each other behind all of our backs for some elaborate April Fools day joke GM has to figure this out.
#469
This issue happened in my 2007 C6 when I changed the battery in the first week of Feb 2019. I ran the diagnostics as described in this thread and found that the errors started on 12/13/18. I can also see the satellite signal strength under one of the menus so it is not the antenna. It most likely will be a software updated that is needed to fix the issue. That is called a firmware upgrade.
#471
Nav radio clock or time
I have 2005 C6 with the clock or time not work also and after the battery reconnected. That's 7 to 10 of us with same problem. I would bet if more C6 owners would disconect there battery they will have the problem too. Is there any more info on what the problem is?
#472
GM is definitely aware of the problem, I thnk they know the cause as well, but have not yet figured out a fix. I was told by the GM rep I spoke with that dealers will reach out to all affected car owners (I think it's more than the tens of thousands of 2005-2010 Vettes with navi) when a cure is found.
One wonders if a cure will "ever" be found if in fact such cure is pricy for GM and the dealers
#473
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19
Don't have Nav in my vette (77 C3) but do in my 08 hummer h2 and it does some of the same things as here. For me when the clock goes away from changing the battery or it going dead there is a hidden menu that can be accessed and I can reset the year, date and clock, it comes back but its off by an hour with no way to correct it. When I try to reset using the correct way (as in the manual) there is no "set" button to select. The red line through the GPS flag is there for a while then goes away. The Area Selection never stays set and my saved addresses get deleted every time I shut the truck off.
Hope they get this figured out soon,
I've ordered a rebuilt unit to replace this one so hopefully it will work.
Neal
Neal
#475
St. Jude Donor '06-13,'16-'17, '19
Tom
#476
I stumbled across a Tech Bulletin dated April 2009 that GM offered a software update to the dealers that was to correct a few issues to certain Nav units. One of the issues this software update corrected was the disappearing clock.
The Update Disc P/N 25956121
Your Vehicle: 2008 Hummer H2
Navigation Radio - Various Malfunctions
TECHNICAL
Bulletin No.: 08-08-44-002B
Date: April 14, 2009
Subject:
Navigation Radio Clock and/or Clock Tab Do Not Appear or Disappears Intermittently, Split Screen, Points of Interest or Exit List Appears While Driving, Text Color May Be Difficult to See, Address Book Characters May Be Hard to Find, Cannot Scroll Through XM Radio Categories, I Agree Screen Lockouts (Update Navigation Radio with New Software)
Models:
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
2008 HUMMER H2
with Navigation Radio RPO UVB or U3U
Supercede:
This bulletin is being revised to add additional customer concerns and to update the list of Operating Characteristics the software addresses. Please discard Corporate Bulletin Number 08-08-44-002A (Section 08 - Body & Accessories).
Condition
Some customers may comment about any of the following conditions:
-The clock and/or clock tab does not appear or disappears intermittently on the navigation screen.
-A split screen, points of interest or an exit list may appear on the navigation screen while driving.
-The text color may be difficult to see on light color backgrounds.
-The address book entry characters may be hard to find.
-The customer may not have the ability to scroll through the XM radio categories while the vehicle is in motion.
-The customer may not be able to scroll through music navigator, MP3 folders, address book, POI's and Turn List when the vehicle is in motion.
-"I Agree" screen appears every ignition cycle.
-Destination entry screens do not have a "back" button to return to previous page.
-Customer is not able to adjust screen brightness while vehicle is in motion.
Important
If the vehicle is not equipped with one of the following radio part numbers, disregard this bulletin.
-15882766
-15882767
-15940102
-15940103
-25797978
-25834072
Looks like they offered a software fix for a few units for the truck units,
If anyone has access to the tech bulletins maybe you can do a search for "Navigation Radio - Various Malfunctions"
The RPO code is the same as mine that this bulletin addresses, I looked for the update disc on the net but couldn't find it anywhere
Neal
TECHNICAL
Subject:
Models:
2008 HUMMER H2
Supercede:
Condition
Important
-15882766
-15882767
-15940102
-15940103
-25797978
-25834072
Neal
#479
Clock not working
Please add me to the list.
2006 Z06 - car sitting waiting to swap out engine and battery died. Once engine fixed and battery fully charged, clock not working and all clock options greyed out in setup.
#480
Welcome to the club of "The clock stopped working." Every day there is someone now with the same problem but only after the battery disconnected. Suggest calling GM and dealership and report the problem. The more of us that do might help to get the problem fixed. As more C6 owner disconnect their batteries more will have the problem, I believe.
