Elite Catch Can
Old Dec 27, 2018 | 05:57 PM
tobb14's Avatar
tobb14
Default Elite Catch Can
is there anyone out there running an elite catch can clean side on a blown c6 grand sport or ZO6 with the dry sump system.
I've attached a copy of my clean side please let me know if anyone is running something similar. I have my clean side running directly to the air filter and the other side plugged.
Old Dec 27, 2018 | 08:44 PM
timd38's Avatar
timd38
No attachment.
Old Dec 27, 2018 | 10:04 PM
tobb14's Avatar
tobb14
Default Catch Can
Clean side catch can
Catch can Installed
Old Dec 28, 2018 | 08:33 AM
timd38's Avatar
timd38
I helped a friend with his SC install, mine is NA, but based on what I see, you need to have a vacuum source on the clean side on the catch can, to pull the blow by into the catch can. My bet is that you are not getting anything into that catch can and if you are, you really have an issue with blow by. Just my opinion..
Old Dec 28, 2018 | 11:27 PM
Dano523's Avatar
Dano523
Elite can on the dirty side, and the below device replaces the line from the tank on the front port out to the air filter line in front of the TB instead.
Hence the clean side is pushed through the replacement cap separator as you have installed, isntead of through the front tank port instead.
http://www.eliteengineeringusa.com/c...oil-separator/
To Elite Catch Can
