Check engine light
Old Dec 30, 2018 | 05:52 PM
keith robinson's Avatar
keith robinson
Default Check engine light
My 2010 grand sport has a check engine light on code 'po445h and p.o.459th large evaporator leak what do I check
Old Dec 30, 2018 | 06:15 PM
crusher1's Avatar
crusher1
HI,
I think you may have typed the codes wrong ---no H at the end PO445,P0459
Check your gas cap is the first and easiest. It may loose..Re-tighten if it is that will throw the code.
Old Dec 30, 2018 | 06:46 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
When I had a check engine light came on, first thing I did was replace gas cap, and in thirty minute drive light went out, and never came back!
Old Dec 30, 2018 | 08:47 PM
crusher1's Avatar
crusher1
Either that or if you have a scanner you can erase the code
Old Dec 31, 2018 | 06:02 AM
keith robinson
Thanks I'll try that
To Check engine light
