Valve cover bolt torque specs.
Jan 8, 2019 | 09:24 PM
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
LS3 valve cover bolts ? What should they be torqued to ?
Or is it like the old school. Just tighten and then one more turn??
Jan 8, 2019 | 09:46 PM
Jan 9, 2019 | 12:00 AM
Quote:
Originally Posted by
Buddy A
106 lb in I believe
Page 6-14 of my 2006 Service Manual agrees. Torque spec for the "Valve Rocker Arm Cover Bolts" is 106 lb in. I strongly suspect the LS3 is exactly the same.
They're squishing a rubber seal anyway so the whole thing is pretty loosey-goosey.
Jan 9, 2019 | 09:42 AM
Jan 9, 2019 | 01:26 PM
Man 106 seems like a lot to me on those small long bolts.
Jan 9, 2019 | 02:49 PM
ptroxx
inch pounds i believe
Jan 9, 2019 | 05:31 PM
rsb213
that makes more sense. I know something was weird.
Jan 10, 2019 | 09:08 PM
St. Jude Donor '15
Jan 11, 2019 | 09:09 PM
lb’s INCH. Finger tight.
Too tight and they will snap off in the head. Then you may get to pull the head. Ask me how I know. LOL.
Jan 14, 2019 | 11:59 AM
jashmore1234
Aren't the heads aluminum? How did you manage to snap off the bolt before stripping the threads?
Jan 14, 2019 | 04:52 PM
RogerRamjet21
I have broken one of these bolts before. I was torquing with a proper torque wrench to the 106 in-lb. For whatever reason, the wrench never clicked and the bolt broke. I think the bolt must have been weak to begin with because it did not take much force at all. Luckily, the broken part unthreaded from the head very easily.
