Intermittant Starting Problem
Old Jan 13, 2019 | 02:02 PM
Don6775's Avatar
Don6775
Default Intermittant Starting Problem
2006 corvette base with 110k miles has an intermittant problem. It turns over but does not even try to start. After sitting from as little as two hours to overnight, it starts immediately, and runs as usual. Three days to a week of normal usage later, same pattern re-occurs. No codes being produced. Any ideas?
Old Jan 14, 2019 | 02:26 PM
TOM WELCH's Avatar
TOM WELCH
can you test starting and running fuel pressure? seems like a reasonable place to look, fuel pump is original I assume.
