Transmission Fluid Change
Jan 21, 2019 | 05:07 AM
Gents what A6 trans fluid are you running/recommend? About to do a round of maintenance before shipping vehicle. At the moment I have about 55K miles.
Jan 21, 2019 | 07:26 AM
Valvoline Dexron VI full synthetic
Jan 21, 2019 | 06:14 PM
U.S. Air Force
St. Jude Donor '05 thru '26
I just had mind done, at the recommended 5 years or 50,000 miles, and had the dealership do it, for what they charged I let them did it, why bother with the mess, and jacking the car to gain access.
Jan 22, 2019 | 12:14 AM
https://www.corvetteforum.com/forums...tructions.html
AC Delco Dexron VI is the factory fill. When you change the fluid, you only get about 1/2 out, so adding the exact same brand back in, assures perfect compatibility.
Be sure to get a filter too.
Jan 22, 2019 | 03:16 AM
@1bdvet how much did it cost you at the stealership? That may be my best option, unless I do a converter while the blower is going in.
Jan 22, 2019 | 08:22 AM
U.S. Air Force
Quote:
Originally Posted by
BlackFya
Check your mail PM sent!
Jan 22, 2019 | 01:59 PM
I didn't get anything from you brother. Try sending it again, please
Jan 22, 2019 | 07:16 PM
Just checked my owners manual on my 13 GS. The recommended A6 fluid change is by mileage only. Standard driving: 97.5K Miles and Severe: 90K miles
Cooling system change 5 years or 50K miles.
You can do this earlier if you want. As mentioned above I wouldn't mix fluids..
Good luck on whatever you do, 2k
Jan 23, 2019 | 09:42 AM
U.S. Air Force
BlackFya
Your right, don't know why I can't send mail, sorry!
Just tried to send me e-mail. and it didn't send, I'll have to look into it!
