Propped Shroud Mod Idea!?!?!?
Old Jan 30, 2019 | 06:25 AM
GUM3Y's Avatar
GUM3Y
Default Propped Shroud Mod Idea!?!?!?
I wondered if anyone has ever considered the idea of 3D printing a spacer for the propped shroud mod? From what I’ve been able to research, it seems that an opening directly in front of the filter can sometimes cause surging due to the turbulent air flow. So folks seem to go through the trouble of removing the shroud, trimming the edges, and then reinstalling. But picture something that looks like a ruler, only thicker with a hole in both ends to act as a solid spacer just for the center of the shroud. If the idea worked, you could get a little fancier with the design, perhaps radius the ends, have corvetteforum printed in script on the spacer, etc. You think it would work???
Old Jan 30, 2019 | 09:08 AM
PCMusicGuy's Avatar
PCMusicGuy
No idea. Can you model or draw something up? I can 3d print it. I have a stock 07 to test fit parts on.
Old Jan 30, 2019 | 05:26 PM
GUM3Y's Avatar
GUM3Y
I’ll shoot you a dm
Old Apr 7, 2019 | 12:26 PM
Omega Doom's Avatar
Omega Doom
I was thinking the same thing any updates
Old Apr 7, 2019 | 08:10 PM
GUM3Y's Avatar
GUM3Y
I ended up buying a Halltech and Jim recommended against any increase in airflow/turbulence right in front of the filter. I dyno’d my car and got some really impressive results so I’m going to leave well enough alone I think.
To Propped Shroud Mod Idea!?!?!?
