NPP Exhaust change
Old Feb 4, 2019 | 01:05 PM
riverrat68's Avatar
riverrat68
Default NPP Exhaust change
I would like to put NPP exhaust on my base 2008 Convertible. I have S&S exhaust on it now. My better half says it drones to much for her.
Trying to find a happy medium. Is it a big deal to change over, and what are the steps?
Thanks ahead of time.
Jer
Old Feb 4, 2019 | 04:46 PM
danzio56's Avatar
danzio56
Jer
If you didn't do any mods to the exhaust when you put the S&S on (I'm not familiar with those) then you basically find a take off set of NPP's and install them from the axle back. Pretty simple replacement, again assuming you didn't modify your exhaust and the S&S is an Axle Back system. You will need to run a vacuum line to actuate the valves in the NPP mufflers. Do a search in here or the General Topics section. There's lots of info on this subject.
Old Feb 4, 2019 | 06:31 PM
Spaceme1117's Avatar
Spaceme1117
Jer
I think the NPP is one of the best factory exhaust systems. Nice and quiet at idle and cruising. But when the by-pass valve opens up at 3500 to 4000 RPM's, it sounds awesome.
A still very quiet with no drone setup that I have on my car (a 2011 Grand Sport) is the NPP exhaust with a set of catted American Racing headers. Little louder than stock when idling and cruising but when the NPP valves open above 3500, it is freaking mean, race car!
Old Feb 4, 2019 | 06:40 PM
jimijam's Avatar
jimijam
Find a set of NPP muffs off a 2008 base C6 and get you one of these to make it work https://www.nakidparts.com/c6-corvet...etrofit-system
Old Feb 5, 2019 | 11:30 AM
riverrat68's Avatar
riverrat68
Default NPP exhaust swap
Thank you, gentlemen. I will get to looking for the "08"NPP exhaust.
riverrat68
To NPP Exhaust change
