HYperflash Harness install
Old Mar 10, 2019 | 05:02 PM
Todds427's Avatar
Todds427
St. Jude Donor '12
Default HYperflash Harness install
Does anybody have the instructions they can send me on how to install this hyperflash harness? I just purchased one and it did not come with instructions. Thank you! (I searched and googled without any luck)
Old Mar 10, 2019 | 05:39 PM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
Assuming it is the Radio Flyer harness (looks like it), check out the installation photo at:
https://radioflyerinnovations.com/sh...or-leds&page=2
Old Mar 11, 2019 | 09:21 AM
Florida_1959's Avatar
Florida_1959
Yes that is a radioflyer for the rear lights.
you can pop out the right rear lights and then put the harness in-between the main one on the chassis and then to the harness running to the lights. It will take care of the both sides so you can use LED with no hyper flash.
Then you can reach in to the center and you will see a stud with a ground wire on it, then mount the resistor pack too it. You want to mount it to that stud so the metal can absorb some of the heat.
I added one and its a slam dunk and it worked great.
To HYperflash Harness install
