HELP: JOHNSON 2116LSR Lifter Experts please advise
When measuring push rod length be sure to keep the oil transfer hole in the rocker adjuster lined up with the oil channel in the rocker body generally (about two turns out) that will live adjusting range as well, when the oil transfer hole is fully lined up (meaning open with out restriction) then proced to measure push rod length with a dial caliper.
As a rule I measure front and rear on both side after the valve is fully and properly adjusted (with the piston @ top dead center on the compression stroke for every valve lash you check) keeping mearuments in writing then take an average for the correct lenght, I hope this can help, David.
I don't trust the turns method to be accurate as my checker turned very easily. I checked mine by getting it close then wrapping the checker in tape to keep it from moving. Once the checker was at the correct length, it was measured using some calipers purchased from Harbor Freight
https://www.harborfreight.com/8-in-d...per-63712.html
See post 11 here when ordering pushrods and discussing length:
https://ls1tech.com/forums/generatio...-pushrods.html
Katech has a good video posted on the topic, and Vettenuts has also started an informative topic. Vettenuts also makes a convincing argument for running the largest diameter pushrods you can fit.
Tooley and Summit both sell house brand 11/32" pushrods if you don't want to spring for Mantons.
FTI. Engine was stock GMPP LS3 525hp. Head not milled and No Valve job during this install. Pistons 0.010 out of the hole.
https://ls1tech.com/forums/generatio...-question.html
https://ls1tech.com/forums/generatio...ation-ls3.html
If you have questions Manton and Brian Tooley have been easy to deal with but you may want to call Johnson again.
