Best bolt ons for LS3?
I have a ‘13 gs and was wondering what are the best bolt ons worth the money that will give good power. And which bolt ons should I stay away from that aren’t going to give much gains.
Supercharger for the Win. A&A.
The following 2 users liked this post by briank17:
tektrans (03-17-2023),
thebarzeen (03-22-2023)
2. Mail order tune or dyno tune (I recommend Diablew for "mail order". Any good dyno tuner in your area for a dyno tune).
Next few are a bit more involved.
3. An cam appropriate to your goals; daily driver, drag car, street/strip combo. But you will need supporting parts; valve springs, pushrods, etc. You can save a lot if you do the work yourself. You will need a good tune to go with it. I recommend going with smaller cam rather than a larger. LS engines respond amazingly well to even small cam upgrades. Larger cams can be difficult to drive.
4. 1.8 or 1.85 ratio rockers are a nice bolt on if you don't want to go the cam route. But you will still need upgraded springs and pushrods. It is a lot less work.
5. Ported stock heads or aftermarket heads.
A supercharger system would also be great but you will spend some money.
Mods That Don't Do Much
Expensive intake = $400 to $500 for almost no gain.
Mods That Some People Really Like
Throttle controller = Some swear by them. I think they are a waste. They are advertized to get rid of the "lag" in the throttle. What they actually do is remap the throttle. (Stock, press pedal half way, get 50% throttle. Controller, press pedal half way, get 80% throttle.) But some people really like them.
unoking (03-13-2019)
First acceleration mods should be a light clutch and gear. I went 11.0@125/126 MPH with 100% stock exhaust. I have a thread (10s NA on stock exhaust) on my build progression. Great bolt ons for a stock cam car: Ported Rod Mod Intake, Ported Throttle Body, Headers, X, Electric Water Pump. Internal mods that free up power: Crank Scraper, 1.85 Rockers (upgrade valve springs & push rods) I managed to make 453 SAE rwhp with my bolt on set up and run 10.5@131MPH Good Luck and Have Fun
Turbotalon1g (05-08-2023)
1. First, best mod/bolt on would be a quality set of headers and x-pipe (I recommend catted). American Racing or Kooks would be my 1st and 2nd choices.
The following 2 users liked this post by LSX228R:
I bought a Vitesse against my better judgement and have returned it due to the car going into limp mode a few times. While I noticed how it took less accelerator pedal pressure to move the car forward compared to stock, after the issues I experienced in my car going into limp mode my original thought I have of these is still the same, I think they are a waste of money. If I want to go fast I will press the pedal further to the floor instead of a controller doing it with less input that may place my car in a limp home mode.
vetteJPJ (03-19-2023)
Glad to hear you haven't had a problem in 5 years, I limped home twice within a month or so because of it, and 5% throttle with the pedal to the floor isn't that much fun in limp mode.
I started off with halltech killer bee and lg super pro headers. With stock base coupe exhaust I still hit 401 hp and 405 tq thru an A6 with tune. I wouldn't neglect the DRM Bilsteins ...I loved the feel and responsiveness after I added them. In all I have barely had 7K seat time in my car. I recently had an A&A kit installed and cant wait to feel the difference. My brother has been the care take and said he wouldn't dare test it out until I get better tires. The halltech will be up for sale as soon as I hit the states next month. Let me know if you are interested.
CAI 400
TB and intake 2500 ported
headers and x pipe 2500
clutch 3000 installed
tune 750
$9150
100 hp give or take
A to A supercharger installed tuned 10000
Clutch installed $3000
$13000
200+hp
tune 750
$9150
100 hp give or take
$13000
200+hp
Best bolt-ons:
1. Kooks headers with cats (ARH can eat my ***).
2. Super charger (ECS or A&A for centrifugal, E-force or Heartbeat for positive displacement blower).
3. Quality tires.
4. Interior insulation kit (cuts down on both road noise and heat to the interior)
3. Quality tires.
The following 2 users liked this post by Spaceme1117:
LightningBrett (03-18-2023),
Start with long tube headers (1.875" primaries) and a tune. If you want to go a little further, throw in a ported and rod modded intake manifold. Forget the ported throttle body as it adds 0 power. If you're still running the stock crank pulley, swap it out for a 10% underdriven unit. Have your tuner up your idle speed 70ish rpm to make up for the underdriven pulley. The above is a good starting point....or ending point for that matter. Just about anything you do going forward (outside of turbocharging or supercharging) will benefit from these mods.
A throttle controller allows you to set throttle response to your liking. I run my Vitesse at SP4; I feel gives pretty close to cable driven throttle response. Drive by wire throttle lag is all but eliminated. I've had it installed for at least 3 years now and it's one of the most enjoyable mods I have as it makes the car drive the way it should have from GM.
Received 3,087 Likes
2021 C6 of the Year Finalist - Modified
Supercharger and a good dyno tune ....
Headers and a cam will be a big benefit if you add them too, but just the supercharger alone with no other mods will still be the best 'bang for the buck'.
so for a bone stock ride, what sort of power might one expect if slapping on an a&a or ecs kit? in my head I figure 550ish to the wheels is about what you'd see? Maybe closer to 600 if you yank the exhaust and run headers/offroad xpipe?
Those figures seem about right?
