LS2 05 vs 06&07
Old Mar 12, 2019 | 01:16 PM
M93Z's Avatar
M93Z
6th Gear
Active Streak: 90 Days
Default LS2 05 vs 06&07
Considering purchasing an LS2 car. Goal is to be high 10's, with heads, cam and usual bolt ons + either nitrous or supercharger. I see that the 05 has the weaker differential and an oddball computer, but I'm interested in it because I'm somewhat familiar with the 4L60/65 series transmission. Looks like the 6L80 will have to be tuned to survive and I don't know anyone with that expertise. Is it better to avoid the 6L80 and deal with the weaker axle? Better to go with a base or Z51. Any input is appreciated.
Old Mar 12, 2019 | 09:20 PM
TucoTom's Avatar
TucoTom
I have a 2007 w/ LS2 engine, love it, but if I was looking for horsepower I'd start w/ the 2008 LS3 engine.
My 2007 has the 6 speed auto trans.
C6 Corvette's are more road car as opposed to drag suspension.
Old Mar 13, 2019 | 03:38 PM
subfloor@centurytrans's Avatar
Supporting Vendor
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Tuning the 6L80 to last isn't rocket science.
Old Mar 14, 2019 | 02:04 PM
M93Z's Avatar
M93Z
6th Gear
If I start with a good low mileage 6L80 and install a converter (3400-3600 stall) and trans cooler, properly set up can I reasonably expect it to hold up to 450+ hp at the rear wheels? Should I expect a competent transmission shop to be able to tune the 6L80 correctly or will I need to locate an engine tuner? Thanks.
Old Mar 14, 2019 | 02:17 PM
Supporting Vendor
Yes, I didn't start breaking my transmissions until I installed an LS7.
If you find somebody with HP Tuners I have a good tune I can send you.
Old Mar 14, 2019 | 09:18 PM
xBoostx's Avatar
xBoostx
I’ll do the 2008 ls3 no need for a superchager to go meet 10 na with a 3400 stall hangs the tires off the line with 3800 Yank pas. Base has lighter brake calipers so straight line advantage
z51 big brakes for auto cross & time attack road race.
Old Mar 15, 2019 | 01:35 PM
M93Z's Avatar
M93Z
6th Gear
If I came across the right car I could go for an LS3 I just wasn't sure if I'd have to dump a ton of money into a 6L80 transmission right away, also the lower price of the LS2 car leaves me with more money for parts. Want to start with a bone stock lower mileage car. Thanks.
Old Mar 17, 2019 | 09:10 AM
05 Wreck's Avatar
05 Wreck
I have the 05. I love the car, but if I was interested in the 1/4 mi, I'd choose the 06-07 with paddle shifters. If the 05 is the best deal, changing the rear diff to 06-up isn't that expensive or difficult.
Old Mar 18, 2019 | 09:27 AM
M93Z's Avatar
M93Z
6th Gear
I was leaning toward a 4L65 with a 3.73 rear gear but it seems although much more complex, the 6L80 with a lower numeric gear will work as well. No rush, just want a nice clean car to start with. Thanks.
To LS2 05 vs 06&07
