Oil Cooler for C6
Old Mar 28, 2019 | 08:15 AM
vairhead65's Avatar
vairhead65
Default Oil Cooler for C6
Anybody know of any oil cooler kits specifically for the C6? I already have a trans oil cooler and don't know if there's enough real estate left for a standard 19-row core. I thought I saw something on You Tube about installing a kit with a narrow core that ran the length of the bottom of the radiator (This might have been on a Camaro). Thanks.
Old Mar 28, 2019 | 11:54 AM
torquetube's Avatar
torquetube
You have a bunch of options. Not only from the aftermarket, but also with factory parts. GM had at least four different engine oil cooler setups for the C6. Two were conventional air-to-oil heat exchangers mounted in front of the radiators, one with a long core (Z06) and one with a short core (Grand Sport). Knowing more about your application would help narrow it down.
Old Mar 28, 2019 | 02:33 PM
vairhead65's Avatar
vairhead65
Oh, yeah... my car is a '09 Base model. Thanks.
Old Mar 28, 2019 | 03:46 PM
torquetube's Avatar
torquetube
Do you need a cooler? How high are your oil temperatures?
Old Mar 28, 2019 | 04:05 PM
vairhead65's Avatar
vairhead65
My oil temp runs around 225 degrees in normal to slightly rambunctious driving. At 100K miles, guess I'm just thinking of things I can do to extend the car's longevity... I'm already hearing a lifter rattle on cold starts and general mild valvetrain noise above 3500 or so RPM. Planning a cam swap, lifters, head machining and perhaps a new oil pump this summer, headers, 3200 stall converter and a torque tube rebuild in a few weeks (I'm doing a lot of overtime).
Old Mar 28, 2019 | 04:16 PM
torquetube's Avatar
torquetube
My oil temp runs around 225 degrees in normal to slightly rambunctious driving. At 100K miles, guess I'm just thinking of things I can do to extend the car's longevity... I'm already hearing a lifter rattle on cold starts and general mild valvetrain noise above 3500 or so RPM. Planning a cam swap, head machining and perhaps a new oil pump this summer, headers, 3200 stall converter and a torque tube rebuild in a few weeks.
Your oil temperatures sound okay to me. The factory air-to-oil cooler setups can run so cold that your engine never warms up. I would suggest looking at the short core (Grand Sport) cooler with an aftermarket thermostat.
Old Mar 28, 2019 | 04:29 PM
vairhead65's Avatar
vairhead65
Sounds like I can put this item on the back burner for the time being. Will look into the Grand Sport option. Thanks for your help, torquetube.
torquetube's Avatar
torquetube
Aftermarket oil cooler thermostat I mean. The factory lines didn't have a thermostat.
Old Mar 28, 2019 | 04:36 PM
vairhead65's Avatar
vairhead65
Gotcha. Have seen a few different brands out there. Thanks.
Old Apr 2, 2019 | 01:14 AM
jonjoy's Avatar
jonjoy
DeWitts radiator with engine oil cooler you can't beat it and the engine temps come down way down also
Old Apr 2, 2019 | 07:04 AM
old motorhead's Avatar
old motorhead
Bingo. And the engine oil temps get to operating temp much quicker than using an air/oil cooler.
Old Apr 2, 2019 | 12:05 PM
torquetube's Avatar
torquetube
This is true, but the flip side is that it's not as effective at cooling. If you're actually suffering severe oil temps, the air-to-oil coolers work better.
Old Apr 2, 2019 | 12:43 PM
R_W's Avatar
R_W
I have an LS3 with a "dry" (more like "damp") sump in my GS, and, since I do a lot of HPDEs, I upgraded my cooler to a Setrab from Improved Racing. They know their stuff and I would recommend them first and foremost.
Old Apr 2, 2019 | 04:13 PM
ImprovedRacing's Avatar
ImprovedRacing
Supporting Vendor
We make a kit for the C6, but it's a high end kit designed for track use, probably overkill for your purposes: http://www.improvedracing.com/oil-co...600-p-768.html
Old Apr 2, 2019 | 04:23 PM
old motorhead
A cooler running engine will have cooler oil temps without any oil cooler upgrades. I added the Dewitts with integral EOC to my M6 Grand Sport. On a cool day, or, worse yet, cold day..... I absolutely hated the fact that it tookforever for the engine oil temps to even get to 150* with the stock air/oil cooler. Yeah, if you're tracking your Vette a lot, an air/oil cooler probably a great idea. For a mostly street driven Vette with an occasional track event, I'd go Dewitts and not look back. My GS could idle, parked, in 95+ degree heat, and the ECT's wouldn't get over 200*. That was with a 160* stat and aggressive fan settings.
The Dewitts was a bolt in affair with just the radiator and GM Z51 oil lines. Pretty easy and effective upgrade.
Old Apr 2, 2019 | 07:39 PM
timd38's Avatar
timd38
Just buy a 2006 Z06 oil cooler kit. Bolts right up!
Old Apr 3, 2019 | 01:24 AM
torquetube's Avatar
torquetube
I too had a DeWitt's with integral EOC and I'm switching to an external cooler. The integral EOC is better for warm-up but at high load I can exceed 280°F oil temperature. The DeWitt's is also pretty expensive; an external cooler and lines is cheaper and easier to install. Addition of an oil cooler thermostat would bring the price up closer to the aftermarket radiator.
Old Apr 3, 2019 | 10:16 AM
R_W's Avatar
R_W
The kit I purchased included a 180* thermostat, which aided in the warming up of oil to 150*. Food for thought.
To Oil Cooler for C6
