Brake question
Old Mar 28, 2019 | 07:09 PM
junkman123's Avatar
junkman123
Default Brake question
I just recently bought a 2006 base corvette with a lil over 50k on it. I assume the brakes are not stock. My question is...are the rear brake pads to small? From the looks of the wear pattern they are.
Car was bought from a dealership so no info from po.any help is greatly appreciated.
Old Mar 28, 2019 | 11:54 PM
KingCorvette93's Avatar
KingCorvette93
Does your car have the Z51 package?
Here's what I think happened:
Your car is NOT a Z51, and thus came with smaller brake rotors from the factory. At some point, the rear rotors were changed to the Z51 size. However, the Z51 caliper brackets - which push the caliper to cover the entire larger rotor - were not installed.
So, you ended up with Z51 size rotors, but calipers that are set up for non-Z51 rotors. These calipers continue to clamp as if they were camping non-Z51 rotors, creating the odd wear pattern.
Not 100%, but a solid guess, I think!
Old Mar 29, 2019 | 12:09 AM
Cherokee Nation's Avatar
Cherokee Nation
That is normal.My Z51 rear pads only contract the rear rotors about 80%.
Old Mar 29, 2019 | 08:24 AM
KingCorvette93
If this is the case, disregard my aforementioned educated guess!
Old Mar 29, 2019 | 09:42 AM
Sox-Fan's Avatar
Sox-Fan
Factory brake rotors are not two piece rotors. Those look to be DBA T3 Club Spec rotors. They may not differentiate between z51 and base brakes with those rotors
@KNSBrakes Ken, can you tell what's going on here?
Old Mar 29, 2019 | 10:47 AM
jaredtxrx's Avatar
jaredtxrx
Pretty typical for a Z51(J55 brakes) car. Here is a picture of some old rotors where you can clearly see the swept area.
Old Mar 29, 2019 | 01:23 PM
junkman123's Avatar
junkman123
Thanks guys. I'm still not all sure what options the car has. I just knew the brakes didn't look factory
Old Mar 29, 2019 | 02:43 PM
HOXXOH's Avatar
HOXXOH
It appears the caliper is likely to be a stock OEM J55 caliper, based upon the configuration and the distance from the wheel.
But the rotor (2-piece with 3 rows of holes plus slots vs 2 rows on OEM J55) is definitely aftermarket.
Look on the glovebox lid sticker for all the option codes and then go to https://www.corvetteactioncenter.com/specs/c6/2006/ and select "Regular Production Option Codes" for an explanation.
Old Mar 29, 2019 | 02:56 PM
KNSBrakes's Avatar
KNSBrakes
Supporting Vendor
The DBA rotors were never machined like that but it's common on the Z51 rotors to machine that whole flat surface even though the pad only sweeps about 2/3 of it.
It's just an oddish rotor design.
Ken
Old Mar 31, 2019 | 04:44 PM
05 Wreck's Avatar
05 Wreck
I'd be more worried about the amount of wheel weight on that wheel.
Old Apr 1, 2019 | 10:57 AM
jaredtxrx's Avatar
jaredtxrx
Gotta balance out all that tire shine!
Old Apr 2, 2019 | 07:16 AM
junkman123's Avatar
junkman123
lmao
To Brake question
