Options unavailable on dash
Instead, the fob your using is programmed into the RCDLR in slot #3 or slot # 4, which these slots do not have a programming option.
So forget what number is on the back of the fob since they are just markers alone, since 4 fobs can be programmed into the RCDLR, and again, only the fobs programming into the RCDLR in slot 1 or 2 will allow options.
As for reprogramming the fob in, you can use the key to do the long 30 min procedure to program the fobs back into the car in the correct order as numbers on the back of them into the slots in the RCDLR (first fob programmed in will be in RCDLR slot 1, then next in slot 2 and so on), or with a Tech II, only takes a few mins instead.
Hence with tech II, you don't have to play the order game, and the tool allows you to program a fob into any of the slots straight away.
