Right Rear Wheel Clunk
Old Apr 11, 2019 | 03:53 PM
SB64's Avatar
SB64
Default Right Rear Wheel Clunk
Noticed pull out of a parking lot today that the right rear wheel made a clunking sound and the car shimmied a little. I have a lift and will put the car up but not sure what to look for. Do we still have half shafts, universals, etc. in a 2006 base model . Maybe the rear. Thoughts!
Old Apr 11, 2019 | 04:35 PM
Sayfoo's Avatar
Sayfoo
Check the axle nut.
Old Apr 11, 2019 | 04:37 PM
SixAddict's Avatar
SixAddict
Check the end links on the rear sway bar, these are known to make some strange sounds. Especially at slow speeds.
easy DIY for about 50 bucks.
Also axle nuts.
Old Apr 11, 2019 | 05:07 PM
SB64's Avatar
SB64
Thak you folks, I will check over the weekend. I restore c3's but just want to get some ideas.
RVZIO
Old Apr 11, 2019 | 10:56 PM
HC Mechanic's Avatar
HC Mechanic
How many miles on the car? Any track use?
Old Apr 12, 2019 | 02:10 AM
SB64's Avatar
SB64
No track use, 36K miles
Old Apr 12, 2019 | 04:14 PM
Plan C's Avatar
Plan C
What you described matches exactly what I experienced prior to replacing my rear end links. Noise disappeared immediately. Hope it's that simple to resolve your concern!
Old Apr 12, 2019 | 05:29 PM
HC Mechanic
I agree with Plan C, rear end links. Mine got so bad that the rear end would step out under hard braking.
I’d highly recommend going with the LG end links, makes a HUGE difference on our cars for rear grip and overall stability. I’ve tried getting a hold of GM engineers about this issue, but didn’t have any luck. Probably the worst OEM part on our cars honestly.
Let me know if you get the LG’s, I’ll help you out with some alignment specs I found to be pretty damn ideal
Old Apr 12, 2019 | 05:43 PM
SB64's Avatar
SB64
Ok that sounds like what I will look at. Now c2's c3's I know like the back of my hand. Need a little direction or a picture of the end links. Sorry still learning c6's
Old Apr 12, 2019 | 05:47 PM
HC Mechanic
These are the ticket
https://www.lgmotorsports.com/corvet...steer-kit.html
Old Apr 12, 2019 | 07:08 PM
SB64's Avatar
SB64
Got it, thank you very much. I will put it up in the air tomorrow and let you know what I found.
RVZIOI
Old Apr 13, 2019 | 01:28 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Re-torque the axle nuts to 140 lbs. If that cures the noise, replace with new nuts.....they are designed torque-to-yield.....just a couple of bucks each. If noise persists, then check end links.
Old Apr 13, 2019 | 05:25 PM
SB64's Avatar
SB64
So, I put the new end links on and I think it's fixed. I will have to check in a short ride. I could not get the car on my 2 post lift which pissed me off. Now I need to check into that also.
RVZIO
Old Apr 13, 2019 | 11:24 PM
HC Mechanic
RVZIO
Nice! What links did you get? Make sure you re-align your girl
To Right Rear Wheel Clunk
