can u run....
Old Apr 14, 2019 | 08:25 PM
mancobra's Avatar
mancobra
Default can u run....
Question : can u run a C6 without a thermostat ? thank u
Old Apr 14, 2019 | 10:36 PM
NY09C6's Avatar
NY09C6
VERY bad to do as a daily driver, especially in a cold climate. The t-stat role is to get the engine to a high temp quickly and maintain it so moisture/condensate can burn out of the oil.
Old Apr 15, 2019 | 10:26 PM
russ472's Avatar
russ472
it would probably take a long time to heat up, but the thermostat also controls flow through the radiator as well. if there isn't a thermostat, the coolant will flow so fast through the radiator, the radiator will not be able to do its job and remove the heat from the coolant. it will eventually heat soak and run hot.
Old Apr 15, 2019 | 11:03 PM
MTPZ06's Avatar
MTPZ06
Could you? Yes
Should you? No..unless you live your life a quarter mile at a time.
To can u run....
