Torque Solutions Transmission mounts
Old May 1, 2019 | 05:55 PM
Trainwrckd1's Avatar
Trainwrckd1
5th Gear
Default Torque Solutions Transmission mounts
I had a driveline noise/vibration under hard acceleration so I installed the Torque Solutions mounts. Now it feels like something's coming undone. vibration is now a shutter and noise is a howl. My Mr Pipewrench pal (GM heavyline tech) went against the manuals procedure of support the diff and carefully lower the crossmember 1 1/2' by loosening bolts by hand. Instead it was jac up diff until new part fit. Easy fix? OR should I start contemplating which "paybacks are a bitch" method shall be used on former Mr Pipewrench friend?
