I'm about to have my LS3 heads CNC ported and am not sure what to tell the machinist in terms of milling the heads. I would like to maximize the C/R for running 92 octane. I'm sure the shop can tell me how much to mill and what gaskets to use if I just provide them with the desired C/R. Inputs greatly appreciated.
Texas speed ported and cncd my stock ls3 heads and I asked them to mill down to 64cc
I am using felpro .41 gaskets I believe my compression is around 11.7- 11.8
93 octane no problem
You can do a lot of milling, use a narrow LSA/high duration/high lift cam and you absolutely have to mock things up and check PTV clearance. Do a little milling, don't go apeshit on the lift and duration, and use a little wider LSA and you'll be OK without checking PTV clearance.
Not sure what other shops do, but if you employ TxSpeed for the CNC work, they also do a valve job. During the valve job, they "sink" the valves into the head to the tune of .010. That increases PTV clearance by that much. I milled my heads .010 and used a .011 thinner head gasket. My static CR went to 11.2:1. Not a huge increase, but essentially free as TxSpeed will mill your heads to your spec as part of the CNC head porting/valve job package. I had to buy head gaskets anyway....thinner ones weren't any more $.
Whoever you buy the cam from can probably tell you what you can get away with milling wise.
Back when I had my 243's ported by Advanced Induction, Phil told me 11.2:1 CR for 91 octane was the max he'd recommend for my set up. We ended up going with 11.1:1 CR.
