Running s bit warm
Old May 23, 2019 | 11:31 PM
shooterrdy's Avatar
shooterrdy
2nd Gear
Default Running s bit warm
Got an 08 LS3I drained coolant put oriely brand thermostat in and now runs warm at idle 210 - 216 idleing 205 down the road. Any ideas drove it abour 100 mile now and problem presist?
Old May 24, 2019 | 01:13 AM
jonjoy's Avatar
jonjoy
Stock thermostat should run about 190 at speed on the highway, did recheck the system if you did a drain and fill it should burp for lack of a better term then you can add more water
Old May 24, 2019 | 07:39 AM
Spaceme1117's Avatar
Spaceme1117
Your car is not overheating but it should be running closer to 195-200 when going down the road.
Most likely you have a bit of debri in the front of the radiator. You could also get under the front of the car to check it. More than likely there is a good bit of leaves, dirt, etc. that is blocking some of the radiator.
Old May 27, 2019 | 12:46 PM
rc51racer's Avatar
rc51racer
05 Z51 6 Speed here. I recently replaced radiator and flushed system, all was good. A few days later my water pump took a dive. While changing WP I replaced OEM thermostat. OE thermostat internals were destroyed. I did purge air out of system by removing the throttle body hose and using a small amount of compressed air to blow toward radiator side and allow coolant to flow from steel line. Took a few times but worked well.
My temps on highway are 196-199°
Funny thing I noticed is the harder I run the engine on the highway the cooler it runs.
Old May 27, 2019 | 06:07 PM
grcor's Avatar
grcor
Make sure you have this flexible black cover is in place. You can remove it to clean out leaves and other trash that might be blocking the oil cooler and radiator and then put it back.
Old May 27, 2019 | 10:22 PM
compyelc4's Avatar
compyelc4
I have an '07 LS2 that runs exactly the same temp as yours. I don't see a problem.
Old May 27, 2019 | 11:05 PM
shooterrdy's Avatar
shooterrdy
2nd Gear
Default Thanks All
I think I forgot to index the thermostat correctly gonna put the stock one back in as it looked like new anyway.
To Running s bit warm
