AC problems
Old May 29, 2019 | 01:45 PM
Tykeela's Avatar
Tykeela
2nd Gear
Default AC problems
My AC went out and I’m trying to figure out do i suppose to have an orifice tube or i need to look at the expansion valve
Old May 29, 2019 | 11:34 PM
Dano523's Avatar
Dano523
For starters, turn the A/C on with the motor running and two things should happen/
1, the raditor fan should come on.
2, you should see the condenser clutch engage to spin the condenser.
If radiator fan comes on, but condenser clutch does not engauge to drive the compressor, may have a broken wire or bad clutch.
If both the raditor fan and the compressor clutch does not engauge, then may have a Bad HVAC control or one of the connector became unplugged (its the unit below the radio).
Now if the radatior fan comes on, and the compressor clutch engages, then need to hook up gauges to the high and low ports to see that pressure amounts.
Here are your charts for the pressures.
http://www.mediafire.com/file/6hw61h...harts.pdf/file
As for reason I say check the pressures, if the system is over filled, there is a high pressure switch that will kick out the system every time
As for your office tube, it on the lower connector to the heat exchanger connection fitting.
To change if if you are getting strange readings on the high/low system, you will need to have the Freon reclaimed to depressurize the system to start with. Change the filter and O ring. Then have the system vacuumed to boil off and remove all the humidity in the system before it can be correctly pressurized charged again.
And again, if you over filled the system with too much pressure/Freon, the high pressure switch is going to shut the system off before it blows a line.
The one last thing to check if the system is just wilding, is to look at the louvered section of the dash to the left of the starter button with a flash light, and see if you can see a Blue bulb just behind the vents. This is the location of the cabin temperature sensor, and if it un-clipped from the bezel and fell into the bowels of the dash, will not have the correct reading of the actual cabin temp/why you think your going through menopause with the cabin too hot/too cold instead.
Old May 30, 2019 | 06:35 AM
Gator6977's Avatar
Gator6977
2018 C6 of Year Finalist
To build on Dano's advice, if you're getting 3 blinks and it's shutting off, I just learned if you have a tech II you can read what the problem is as that kicks up a code. High pressure, low pressure, bad ambient sensor, bad compressor, low voltage or engine temp too high are all culprits. I just had to change out the ambient sensor on the wife's Acadia.
To AC problems
