Which mod list is "better" ?
I've found two that interest me and given their mod list which car sound most suitable to my planned usage:
1) 2008 Z06 Engine Modification by Cliff Summers (Tech at 21st Century Muscle Cars):
· Stock TB and intake are completely ported - Peak Speed shop in CO
· Heads - Reher Morrison Racing Engines - CNC ported and hand finished by Darin Morgan. The intake valves are factory, exhaust are solid stainless, new springs
· Comp Cams - trunnion upgrade
· Katech K501 Camshaft
· Carbon Fiber K&N Open Air Cleaner
· Stock bottom end
· Pfadt 1 7/8" with catless X – NPP Stock Mufflers
· Tuned by Matt Garzoni and 21st Century Muscle cars in Addison.
· 593rwhp on 93 with a strong TQ curve at 517rwtq
· 21st also replaced the diff/trams fluid
· New Parts Installed July 2017 – lifter chirp
· Cam K501 Katech KAT-6701
· Timing Chain Katech - HME-G68V-2
· Belt Tensioner Katech - KAT-A4425-BLK
· Lifters Johnson 2110
· Push Rods - Comp 7.775
· GM Lifter Trays
· GM Head Gaskets
· New Z06 Clutch GM LS7 Stock
· Head Bolts - ARP 134-3610
· Crank Bolt - ARP 234-2504
· Pat G drivability Tune
Suspension Mods:
· Pfadt Featherlite Coil Overs – Single Adjust
· Pfadt Sway Bars front and rear
· Performance Friction – ZR33 Big Brake Kit
· SPL Parts Bumps-steer kit front and rear
2) All mechanical work was done by Jonathan Anderson/Nemesis Racing and
SS LSX for your tuning pleasure. Most mods done within the last 10k miles.
2007 Corvette Z06
I believe its a 1lz trim
Engine:
Lingenfelter Intake and MAF
160 degree thermostat
WCCH stg 2 heads
CHE trunion upgrade
New GM lifters
BTR 660 spring kit
BTR pushrods
APR cam bolts
APR balancer bolt
BTR stage 3 OTS cam
Ported stock Throttle body
New Timing Chain
Kooks 1 ⅞ headers
3” x pipe no cats
NPP Z06 exhaust
Interior:
Corvette Mods leather seat upgrade
iSimple Aux/Iphone input
Entire rear hatch lined with Second Skin sound deadening
Exterior:
Morimoto LED full headlight replacement
New front Lip 11/18
Smoked tail lights
Oracle LED foglights
Stock mint condition Spyders to be sold with the car
DBA disc brakes
Powerstop z23 pads all around (have an extra set of front pads purchased at the same time as ones on the car)
also have for sale but will give the new owner the first dibs
New 355/30/19 rears 400
NGP stage 5 heads ($2000) made 580hp on 93 octane
Custom grind cam 247-375/261-365/ 112 + 0 ($300)
Stock LS7 cam (came with car) $75
iForged Aero 3 piece wheels 18/19 (3k)
LG gt4 exhaust ( sounds amazing) (600)
Ebay zr1 side skirts 100
Powerstop z23 front brake pads to go with car
Stock Headlights to go with car
Hence without knowing the age of the suspension or other mods, may have a suspension/motor that is ready for rebuild.
As for the LS7, problem has been the available room under the hood to get a LS7 to breath all the way up to 7K to pull hard to its Stock red line limit, and with the super charger just making enough air pressure on the top edge, motor will pull hard to 7K/ put you in the 650hp range, and the motor not different in manners than a stock motor. Better than this even, just off idle with the heart beat, the motor is putting out close to 600ftlbs of linear torque as well.
As for your best best, find a Bone stock Z06 to start with, so you not having to deal with someone elses mod problems and can build it to your needs isntead.
