Take your Delphi 85 MAF sensor and use it as a paperweight. Move up to the LS6 style card MAF. We provide a genuine GM MAF sensor, our own conversion wire harness for plug and play installation. No cutting required at all.
This inductions system when bolted on the C6 Z06 has pushed the limits of bolt ons to under 10 second passes. The LS2 runs 100% better, with our huge Super Bee filter. Originally dynoed by Katech it added +15 HP on their dyno.
3 in stock ready to ship tomorrow.
Jim Hall
__________________ "World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
Jim Hall
Saw a dyno for a Z06 the Killer Bee and time, looked like it produced more front end torque, quite a bit. Is this common Jim? Free freight on this unit?
This intake, with proper tuning should add close to 25 RWHP to the otherwise stock LS2. The engine will love you. We use the same SuperFlow filter used on the Killer Bee intake for the Z06.
The torque is what generates the HP. Yes, it is massive.
Free freight within the 48 states.
"Take your Delphi 85 MAF sensor and use it as a paperweight. Move up to the LS6 style card MAF. We provide a genuine GM MAF sensor, our own conversion wire harness for plug and play installation. No cutting required at all.
This inductions system when bolted on the C6 Z06 has pushed the limits of bolt ons to under 10 second passes. The LS2 runs 100% better, with our huge Super Bee filter. Originally dynoed by Katech it added +15 HP on their dyno."
I have the Killer Bee CAI already from you, do you sell the LS6 style MAF, separately for the LS2?
The probe style MAF comes with the package, but will not work with the stock LS2 intake at all. The stock intake uses the Delphi 85 style MAF. (The entire intake is tossed (except in CA where you want to keep your original intake for smog)
So, if I'm looking at a head and cam package, what intake is compatible with your maf conversion?
