Mild to Wild C6 Add-on
I am a new owner of a 2008 C6 Automatic Coupe and the car came with the add-on accessory where the NPP exhaust can be programmed to stay on all the time. Curious to know if that accessory will allow me to run the car in the "mild/quiet" mode full time using the fob that came with it. I tried to change the exhaust with the fob and didn't notice any difference so not sure if the battery needs to be changed on the fob. So right now, the exhaust has a nice growl on acceleration and then quiets down as it gains speed and goes through the automatic shifting which I believe is the standard sounding exhaust.
Any help would be appreciated.
Mike
Mike
Start your car, walk to the back with your fob, look in the exhaust and see if the flaps on the center exhaust are open or closed. Press a couple buttons and see what happens with the flap.
In normal (mild) factory mode the flaps should be closed at idle and only open at high RPM. One of your fob buttons should open the flaps and keep them open all the time (wild).
If the flap doesn't work with the fob start by replacing the fob battery.
Received 1,597 Likes
It is possible to override the NPP and keep it closed all the time (Dashlogic does it in "quirt mode"), but I do not know if your setup is capable of that.
Please let me know. Thanks in advance.
Mike
If you hate the NPP Exhaust I'm betting you can find someone local to swap you for the stock exhaust and also pay your part to have the work done as the NPP exhaust is very popular.
You could also simply remove the M2W unit and drive the car like a little old lady, that should shut it up :-)
Originally Posted by Iceaxe
Nope, the NPP Exhaust always opens under hard acceleration, that's what the original buy paid the extra $1200 for when new.
Thanks for taking the time to post though even if your post was a waste of time to read and respond to :-(.
The Dashlogic module will do what you want. It's a simple plug and play module. Dashlogic gives you the option of using your mirror switch to switch the NPP from normal mode (I.e. Stock - open @ ~3500rpm) to fully open or fully closed modes. In the fully closed mode, it will stay closed no matter what the TPS or RPM is at.
This will make your M2W switch redundant so you will want to remove it.
Dashlogic
https://www.palmerperformance.com/st...products_id=76
Good luck.
Dashlogic
Good luck.
Dashlogic
Good luck.
Dashlogic
Good luck.
Why don't you go back to the kitchen as men are talking cars here.
***Thumps chest***
***Thumps chest***
Mike, with NPP that is operating "normally", the flaps in the exhaust should open when you turn the ignition off. That means they are open at startup but quickly close after starting the car. Then they should stay closed unless and until you accelerate hard enough that the system opens them up, then they close again when the RPM's come back down and should stay that way under normal cruising. All the Mild to Wild does is give you the option to force them open at all times (Wild mode). When Mild mode is turned off, it should put NPP back to "normal" as I just described. However, I believe I read that with the Mild to Wild installed, the flaps should stay in whatever position they were in when you turned the car off, so I assume that means they would stay closed at shutdown rather than opening back up. I wish I could tell you for sure from my own experience, but I bought a Mild to Wild switch for mine only to find that I have a bad solenoid or vacuum leak or something that causes my flaps to stay open all the time. It's not the fuse because I checked and even replaced mine with a new one. It's something I'll get around to fixing but not a priority since my intent in getting the M2W switch was to leave them open most of the time anyway.
