Rear wheel side to side play
Old Jul 30, 2019 | 11:56 PM
SivaSuryaKshatriya's Avatar
SivaSuryaKshatriya
Default Rear wheel side to side play
Hi all,
I have a C6Z, and the rear wheels have a lot of play side-to-side (toe). I believe this is the tie rod ends.
Looking online, some people have noted that C5 rear tie rods don't fit the C6, and vise-versa.
However, SPL parts (who I trust when it comes to suspension parts) says that their rear tie rod ends will fit both the C5 and C6 - is this because the adjustable nature gives it more thread to play with?
http://www.splparts.com/products/spl...nds-c5-c6.html
Old Aug 1, 2019 | 01:39 PM
SivaSuryaKshatriya
bump
Old Aug 1, 2019 | 04:39 PM
Dutch08's Avatar
Dutch08
So if you have any play, you have a problem.
Now when you grab the tires (vehicle is lifted in the air by the lift points and not the tires ) at 12 and 6 o'clock and then at 9 and 3 o'clock where do you see the movement in the suspension components when you see the play?
Old Aug 2, 2019 | 07:01 PM
SivaSuryaKshatriya
Thanks for the response Dutch. I didn't actually test it myself; my mechanic mentioned it was the rear tie rods after he checked the wheels during an oil change.
I should have rephrased my original question; I'm more curious about whether the SPL tie rods really do fit both the C5 and C6, because some have mentioned C5 tie rods aren't compatible with C6 ones.
Old Aug 3, 2019 | 09:14 PM
SivaSuryaKshatriya
Installed the SPL tie rods today without issue. My car feels way more stable now under accel and braking, so bad tie rods must have been the issue.
To Rear wheel side to side play
