110 lsa
Old Aug 1, 2019 | 04:28 PM
Brent Scott's Avatar
Brent Scott
Default 110 lsa
Anyone run a cam grind with a 110 LSA, or lower on there LS3?
If so what was your vacuum at?
Thanks!
Old Aug 2, 2019 | 09:49 AM
luka2sb's Avatar
luka2sb
completely dependent on duration.
you could have a small duration cam with 110 LSA that has good street manners, and a large duration cam with 110 LSA that can barely idle and sucks to drive on the street.
if you have duration and LSA, then calculate EVO, EVC, IVO, IVC. the relation between EVC and IVO is called "overlap" that determines idle quality.
Also "vacuum" won't tell you anything since someone can set their "idle" at 1400 rpm and have plenty of vacuum but the car still has poor street manners, while someone at 700 rpm idle has less vacuum but the car has very nice street manners.
Exaggerating the example here but you get the idea.
what you should have asked is "What amount of overlap is in your cam, and how is drive-ability" and you will get a very wide range of answers because what is a "very good street cam" to one individual , is a "this cam sucks for the street" to another individual.
Old Aug 2, 2019 | 09:54 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
As a comparison ... here are the specs of the OEM LS3 cam:
Dur: 204°/ 211°
Lift: .551” / .525”
LSA: 117°
ICL: 120°
Overlap: -26°
Old Aug 2, 2019 | 11:39 PM
KW Baraka's Avatar
KW Baraka
Dur: 204°/ 211°
Lift: .551” / .525”
LSA: 117°
ICL: 120°
Overlap: -26°
But the same cam with a 110° LSA will have about -12.5° overlap....and will STILL have a baby smooth idle.
As stated, the LSA is much less important than the duration and overlap.
KW
To 110 lsa
