Ticking/squealing noise from engine
Old Aug 6, 2019 | 10:16 PM
jpshoar's Avatar
jpshoar
Default Ticking/squealing noise from engine
Had gotten oil, coolant, spark plugs, plug wires, alternator serviced with a retune on my supercharged camd ls3. Noise came on that night. Originally sounded like a knocking sound but disappeared until the day after where it reappeared more of a squealing sound. Car drives perfectly fine. It sort of sounds like the noise is most prominent at idle and gets quite with higher rpm. It could just be that my exhaust drowns out the sound but I'm not certain. Mechanic thinks its lifter noise. What do you guys think? I'll link sound clips.
Noise from that same night
Noise that reappeared after a day
Old Aug 9, 2019 | 07:53 PM
farmington's Avatar
farmington
Balancer or tensioner?
Old Aug 10, 2019 | 07:42 AM
Spaceme1117's Avatar
Spaceme1117
I would also suspect a bad lifter.
Old Aug 10, 2019 | 10:30 AM
BLUEMEANIE's Avatar
BLUEMEANIE
Get a stethoscope from harbor freight it’s $10.. take your time and touch and listen to everything.
you will narrow down the issue and opinions
My death noise/rattle turned out to be the starter shield rotting away.
good luck, hope it’s a simple fix
To Ticking/squealing noise from engine
