Transmission compatibility
Old Sep 1, 2019 | 03:25 PM
chris bivens's Avatar
chris bivens
2nd Gear
Default Transmission compatibility
I have a 2005 Z51 with 6 speed manual with the 1-4 skip shift.
I lost ability to shift into 1st gear while still moving. Now I have a scream coming from what seems to be the transmission. It will pop put of first gear.
I found a 6 speed remanufactured for a Z06. Is it the same as what I have.
My car is Supercharged by Lingenfelter with their 600 magnuson package. I have this transmission in the cart on Ebay. Anyone certain please let me know.
Old Sep 1, 2019 | 05:25 PM
rsb213's Avatar
rsb213
It won't work without changing the diff as well to my knowledge. You can use the base non z51 t56 without the trans cooler if you prefer to save the money but you again are losing the cooling capabilities on the z51.
Old Sep 1, 2019 | 06:04 PM
chris bivens
2nd Gear
Default Thanks
Thank you for the information. Might upgrade everything to the Z06 stuff. I dont drive it nicely all the time.
To Transmission compatibility
