DIY Tuning
Old Sep 9, 2019 | 08:43 PM
Dutch08's Avatar
Dutch08
Default DIY Tuning
My Corvette is my hobby. I told myself that I would do 100% of my own work or sell the car. Stupid I know, but that whats I want to do. So far I find the 05 vette easy to work on. I've done a number of things and the clutch replacement was the most work but (IMHO) not that hard.
So my questions. Can you tune a car by yourself in a home garage? I am willing to spend a few bucks, but not on something like a dyno. HP Tuners has a course that you can take to teach you how to tune which I plan to enroll in.
So again, "can you tune a car" in your home garage? Opinions, have you done it, can't be done, how did you measure results, etc.
Old Sep 9, 2019 | 10:32 PM
99blkfrc99's Avatar
99blkfrc99
HPT and Goat Rope Garage.
Old Sep 10, 2019 | 05:52 AM
Dano523's Avatar
Dano523
Fastest way to blow up a motor, try tuning a motor without a clue.
Hell, the amount of shops that have blow up motors with techs that did not have a clue is noted as well.
Old Sep 10, 2019 | 08:44 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Yes you "can". But in short, it takes many hundreds of hours; computer literacy, and is best to attend one or more schools like the Tuning School.
Old Sep 10, 2019 | 09:56 AM
Hitman227's Avatar
Hitman227
R u computer literate/advanced? IF so, AND you are familiar with how an ICE operates, ls1tech has a beginner's guide (*.doc file) to computer tuning [w/HPT].
Read that document top to bottom and then re-evaluate the situation!!
Old Sep 10, 2019 | 04:08 PM
davidfarmer's Avatar
davidfarmer
It’s easy to tune a bolt on car, just follow the fuel trims. If you have a big cam etc and want a streetable car, you should find a pro
Old Sep 10, 2019 | 04:58 PM
luka2sb's Avatar
luka2sb
Definitely; well ... not in the garage, but on the road or drag strip (without a dyno).
As others have answered, before you do it, i think you should learn some basic engine control theory. Personally i bought a couple of small books, did some reading on engine control theory, then very slowly and gradually started changing calibrations, started with small benign stuff that doesn't risk the engine then progressed from there. if you don't already know how the ECM measures signals and controls the engine, it will be a little bit of a learning curve. Personally i enjoyed the process and i consider it a hobby, mostly just tinkering really. If learning this doesn't sound enjoyable to you, just have a tuner do it.
Hardware wise you'll need some sort of an interface to flash the controller, i use HPTuners, but i think EFI Live is also popular. You will also need to buy a wideband O2 sensor setup, and wire it in so that HPTuners (or equivalent) records air fuel ratio alongside ECM variables.
if you want to chat a little more in depth what it takes to tune, send me a PM.
Old Sep 11, 2019 | 09:18 AM
jim2092's Avatar
jim2092
St. Jude Donor '08
Reminds me of what seemed like a hundred hours to set up my wideband etc. to tune in Lambda. (allows you to tune without knowing what type of fuel is being used). Very useful.
Old Sep 11, 2019 | 10:34 AM
Dutch08's Avatar
Dutch08
Thanks I'll keep you mind and add you as a friend.
Your response is exactly what I was looking for. I just want to tinker and maybe make some small changes down the road to match headers etc. It's my hobby and keeps me out of trouble. I enjoy playing with the car almost as much as driving, its as simple as that. I just wanted some idea of the amount of work study involved. I'm going to use HPTuners and take a few of their courses. Thanks!!!!!
Old Sep 11, 2019 | 05:54 PM
Hitman227's Avatar
Hitman227
There's a way to tune for street power W/O necessarily investing in a wideband...read the document I mentioned - proceeds to outline this particular method.
To DIY Tuning
